dumb question. removal of head.
Old Jan 1, 2013 | 06:58 AM
KtHaNxBai's Avatar
Default dumb question. removal of head.
so i removedthe head and all the rockers fell out of place..do all i need is a valve adjustment to get them back in place???
Old Jan 1, 2013 | 08:05 AM
JuicedUpRice's Avatar
Default Re: dumb question. removal of head.
Yes.
Old Jan 1, 2013 | 11:29 AM
fcm's Avatar
fcm
Old Fart
What do you mean, "and all the rockers fell out of place"?
I want to see a pic. of that. 94
Old Jan 1, 2013 | 11:54 AM
ashleyroachclip's Avatar
I believe the dohc non Vtec head, once you remove the cams the rockers will come right out.
Generally the rule is to place them back in the position the came from , and the reason is they wear in to that particular lobe on the camshaft.
I have had to just install them and not known which location they came from and had no ill effects.
Old Jan 1, 2013 | 01:08 PM
KtHaNxBai's Avatar
thank you
Old Jan 2, 2013 | 06:47 AM
fcm's Avatar
fcm
Old Fart
Hmmmm, OP said head, "so i removed the head" not the cams???? 94
HondaJax
Engine Machining & Assembly
Jan 7, 2019 08:43 PM
u_tal
Dec 31, 2009 11:23 AM
canuck-mx6
Apr 14, 2003 11:52 PM
onyx00
May 7, 2002 01:28 PM
JSpecwest
Jan 24, 2002 12:39 PM
