Idle surging
Old Dec 31, 2012 | 03:41 PM
honcrf150's Avatar
Icon3 Idle surging
Before posting PLEASE read
I have searched and searched and searched some more...Have not found a cure, been on this for a few months..
I have a surging/bouncing idle on my DPFI engine.
-It gets worse the hotter it gets.
-Might go away for a few minutes but then will fluctuate idle RPM's
-Idle calms down if electrical load is put on the car (lights, wipers etc)
-When unplugging IACV, that also fixes the idle.
What I have done that has not worked
Cleaned IACV
Replaced IACV
FITV-because I don't have one.
Cleaned up all grounds
Adjusted throttle cable tension
Ran a fresh wire from IACV plug to ECU
Bled Coolant
Checked for vacuum leaks with carb cleaner
Reset ECU
Checked alternator charging voltage
and i'm probably forgetting some things i've already done...again, what is very interesting is the electrical load issue, that is what doesn't make sense..
Anyone come across this crazyness?
Old Dec 31, 2012 | 04:43 PM
diesel718's Avatar
Default Re: Idle surging
learn to read...it says he replaced it.....might be possible tps problem
Old Dec 31, 2012 | 05:33 PM
Tim512001's Avatar
Ugh tps on dpfi... #hate
Posted from Honda-tech.com App for Android
Old Dec 31, 2012 | 05:48 PM
honcrf150's Avatar
I'm going to inspect the TPS tomorrow, doubtful that will be it (hopefully it is though).
Old Jan 1, 2013 | 04:03 PM
honcrf150's Avatar
The idle bounce is fixed, I backed out the idle screw 1/4 turn and that's all it took.
But my problem with turning on the lights/wipers causing the idle to drop has gotten worse. Now the car will almost stall itself. Ideas?
RinzEG6
Nov 24, 2014 12:02 PM
downshift3r
Sep 30, 2013 06:34 AM
mitchh29
10
Mar 6, 2013 08:18 PM
jdm_prelude19
Apr 4, 2011 05:58 PM
chrisbell37
Aug 25, 2006 12:31 PM
