5th gen. prelude oxygen sensor locations
I,m sorry if this has been covered . I searched the forums and nothing came up,unless I,m doing something wrong. I had the O2 senor changed in the catalytic converter but my check engine light is still on. Where is the other one? Thanks
one right before the cat, then one after the cat
just google "5th gen Prelude oxygen sensor locations"
key is to make the sentence simple and use the important keywords, google does the rest, and you still will probably end up here
Did you reset your CEL or ECU...this can be done by pulling the under hood Radio 7.5a fuse for 30 seconds.
