Drove through huge puddle. Headlight moisture question
Old Dec 30, 2012 | 07:31 AM
Coopa B18c5's Avatar
Default Drove through huge puddle. Headlight moisture question
Hello so the other night it rained really bad here in south jersey and on my way home from work it was dark out so i didnt see this monster puddle and I ended up going for a swim. Now BOTH headlights are full of moisture...
Do u truly have to take them out and bake them? You know the whole 9 yards or will they dry up on their own..?
Just wanted to double check before I go through all that. Thanks again!
Old Dec 30, 2012 | 09:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: Drove through huge puddle. Headlight moisture question
You will have to remove them, [it] to dry them out properly, but more importantly to find out why the moisture got in in the first place.
Is the housing "split" at the seam, is there a hole in the housing or is it just bad gaskets at the bulb housings.
If it is just bad gaskets you can dry the housing with a blow dryer or heat gun, I have even used compressed air without removing the housing and then replaced the gaskets. 94
Rok_Stok
Dec 31, 2009 08:19 PM
mugenpowered
Jan 14, 2006 03:41 PM
93h22a1vtec
Jan 11, 2006 05:49 PM
GruvyTune
Mar 19, 2002 08:50 AM
