1996 accord wont start when cold
Old Dec 30, 2012 | 06:18 AM
Brando76's Avatar
Default 1996 accord wont start when cold
I have some issues with 96 accord 4cyl., will not start when cold outside, when its warm it starts and runs no problem. I pulled a spark plug attached to wire and touched to ground tried to start to look for spark I got 1 spark then nothing more, any ideas?
Old Dec 30, 2012 | 09:52 AM
go-part's Avatar
Default Re: 1996 accord wont start when cold
Starting off with your spark issue, have your battery tested.. load tested. Also figure out if you have enough cold cranking amps
Then checked to make sure you are getting fuel. When was the last time the fuel filter was replaced?
Old Dec 30, 2012 | 10:11 AM
TrickshoT_CD5's Avatar
check either ure igniton coil or distributor
Old Dec 30, 2012 | 10:15 AM
Brando76's Avatar
Just bought a brand new battery, starts fine when the outside temp warms up
Old Dec 30, 2012 | 10:16 AM
Brando76's Avatar
I replaced distributor cap and rotor yesterday
Old Jan 1, 2013 | 02:06 PM
brakedrum's Avatar
Assuming everything else is in tune, you probably have a weak ignition module (ignitor) which is in the distributor itself that the cap attaches to. A failing ignitor can deliver the spark to ignite combustion in moderate weather, but not in bitter cold temps when the module has gotten completely cold. Problems starting after sitting for hours in cold temps is a sure sign. After multiple tries it will start. That's because the ignitor warms a tiny bit on each attempt and finally gets the engine fired up.
A few years ago, I confirmed my ignitor was bad by keeping the bitterest air off of the distributor by simply wrapping a towel around it while it was still warm the night before. I wrapped it around the cap and the distributor itself. Next morning it started right up. Problems starting when the towel was left off the following night. Apparantly it only take a few temperature degrees to make all the difference. I put in a fresh ignitor and had no more trouble. I even started her up one morning when it was 0º outside.
Closetgeek
Dec 9, 2015 04:45 PM
Niosa5
Mar 30, 2013 09:43 AM
Boostedyota
Jun 14, 2009 05:18 PM
nickmcpher
Aug 21, 2008 05:10 PM
crunked4477
Aug 5, 2004 11:44 PM
