lean burn possible on b series with egr and permanent wideband?
Old Dec 29, 2012 | 04:56 PM
raverx3m's Avatar
Default lean burn possible on b series with egr and permanent wideband?
if i have a permanent wideband sensor installed in my car can a b series be tuned to have leanburn? high compression motor?
Old Dec 30, 2012 | 06:13 AM
grumblemarc's Avatar
The Grumpiest
Default Re: lean burn possible on b series with egr and permanent wideband?
Why not?
Old Dec 30, 2012 | 10:49 AM
raverx3m's Avatar
I was hoping for more details lol.
Besides lower emissions what are the benwfits of having an egr valve?
I was reading wiki yesterday and it seems like egr is also necessary for leanburn to keep the exhaust temps down. But they also mention that cam overlap on newer cars is also used for that when both valves are open.
I was thinking a prelude or accord have egr valves and would be closest to b series.
Old Dec 31, 2012 | 05:11 AM
kyden's Avatar
automatic da's came with an egr valve.
i don't see the point, as you should be getting 30+ mpg anyway.
Old Dec 31, 2012 | 05:42 AM
The Grumpiest
I don't know why you just don't tune it for economy under a certain RPM. Seems like a lot of trouble to go through for what seems like a relatively simple solution.
Old Dec 31, 2012 | 07:06 AM
spAdam's Avatar
Loved
Community Favorite
That's pretty much how EGR works. The routines in the ecu for controlling it are not totally straightforward as I remember, and I'm not familiar enough with the lean burn programs to comment on how they implemented it there.
You could always try shooting for some targets like I've attached below to see if they make a dent. It's pretty conservative, but it was enough to get me from ~265/tank to ~315/tank... about a 19% decrease in average consumption! I'm not willing to push it up over the NOx hump to get a true lean burn, and I know for a fact that it could use some work on the timing, but I'm pretty happy with the results.
Old Dec 31, 2012 | 08:37 AM
bgdriver's Avatar
I had a d15b2 that I leaned out to 19:1 with 50+* of timing for some parts of cruise and I had a best of 489 miles per 10 gallon tank all city driving. No egr either but the plugs were pretty bad afterwards, I wouldn't necessarily recommend it for a motor that you cared about.
Old Dec 31, 2012 | 09:36 AM
raverx3m's Avatar
Thats what i meant. The egr is there for real leanburn to lower the temps
portflow
Apr 30, 2013 05:08 PM
91 DA Revived
Jun 17, 2010 07:05 AM
b20steveo
May 28, 2009 01:28 PM
neo_
Nov 6, 2007 05:57 PM
garagespecial
Jul 3, 2003 03:15 PM
