Sputters and Bogs Down at Accelrating
Old Dec 28, 2012 | 04:27 PM
liqui1101's Avatar
Default Sputters and Bogs Down at Accelrating
The Problem:
The car will idle at ~900 rpm. I can accelerate in neutral but sputters a bit. I put it in first, let out the clutch, give some acceleration and just starts to sputter and bog down.
Random part is, if I put it in first, slowly let the clutch out without accelerating, it will start building speed slowly. However I can not accelerate otherwise it will sputter and bog down.
Things I have checked:
-Throttle Positioning Sensor reading good voltage at closed/open throttle.
-Manifold Absolute Pressure reading good voltage at low/high vacuum.
-Compression is good at all four cylinders.
-Brand new spark plugs properly gaped.
-Brand new spark plug cables.
Additional Information:
-1993 Honda Civic Hatch CX
-Swap the D15B8 to D16Y7
-Kept OBD1 harness and used D15B8 distributor, injectors, oxygen sensor, and ECU (P05)
-Running a D16Y8 Intake Manifold
Old Dec 28, 2012 | 07:00 PM
jbpnoman's Avatar
Default Re: Sputters and Bogs Down at Accelrating
Check your timing. Also, you should probably look up the specs on the injectors you're using - they might not be flowing enough fuel to keep the Y7 fed.
Old Dec 29, 2012 | 09:13 AM
slo_hatch's Avatar
It sounds like a timing issue to me. They will do things like this when they are a tooth out of time. Check your timing to make sure it didn't jump.
Old Dec 29, 2012 | 08:33 PM
liqui1101's Avatar
Thank you guys. I will check that. Oh and the D15B8 and D16Y7 are both 180cc injectors, 2 pin, but differ outline so OBD1 harness plastic clip won't plug in to D16Y7 in injectors.
This is my first rebuild so I could have skipped a tooth. However if I did, wouldn't that cause the valves to clash with the pistons? I made sure to do a few manual rotations to make sure they weren't touching.
Old Dec 29, 2012 | 08:49 PM
jbpnoman's Avatar
One tooth won't. Good on you for looking up the injector sizing.
Old Dec 30, 2012 | 01:46 AM
spoonegmalta's Avatar
a simple fix might be clogged injectors ... try using injector cleaner you might get away with a cheap fix
Old Dec 30, 2012 | 08:04 AM
vtecthusiast's Avatar
Do u have cel on? I had a code 41 bad o2 sensor heater i changed the sensor and doesnt stutter at all now!
Old Jan 1, 2013 | 06:41 PM
1dumpedeg's Avatar
Have you tried just cleaning your throttle body? Mine was doing that a few months back, gave it a quick clean and has been fine since
Old Jan 5, 2013 | 06:37 AM
liqui1101's Avatar
Hey guys, just to close this thread, the timing belt was off by 1 tooth.
JuneBugDrfter
Sep 17, 2013 05:29 AM
Hanmin
Sep 17, 2012 10:44 PM
Voodooboy520
Jan 21, 2010 02:40 PM
AB16A2T
Feb 1, 2007 10:07 AM
nutball72
Mar 21, 2006 12:35 PM
