ITR throttle cable same as LS/GS for S2 intake on gsr
Old Dec 28, 2012 | 02:38 PM
B_Swapped93's Avatar
Icon2 ITR throttle cable same as LS/GS for S2 intake on gsr
Got a Skunk 2 IM for My 94 GSR was told i'd need a new(different) thottle cable(LS/GS) b/c of the TB in a differet location. was wondering if a ITR one would work can't find a GS/LS one.
Old Dec 28, 2012 | 07:12 PM
KYNgsx's Avatar
Default Re: ITR throttle cable same as LS/GS for S2 intake on gsr
You can use your stock GSR throttle cable if you're using the stock GSR throttle body with the throttle cable attached to the throttle body.
ITR cable mounts to the intake manifold and pulls in the opposite direction.
Old Dec 28, 2012 | 07:36 PM
mouab18c1's Avatar
You match the cable to the cable mount.
Old Dec 28, 2012 | 07:56 PM
drmix's Avatar
What you wanna do is swap out the throttle body pulley for one from a ITR/LS/GS (also heard that most civics have the same pulley) then swap out the cable from the same model. You also wanna grab the throttle cable bracket too. Heres a pic of mine all swapped over:
Before-
After-
Old Dec 28, 2012 | 10:31 PM
@drmix Thank you very much for those pics ! so what im looking for is a LS/GS pully,cable and bracket ?
Old Dec 28, 2012 | 10:36 PM
drmix's Avatar
Yeah thats what you want. When I changed mine over I just ordered a brand new ITR throttle cable and bracket from Honda then went to the wrecking yard and grabbed a pulley. I looked at a friends LS and the bracket looks the exact same as what I got so I am sure the cable should be too.
Old Dec 28, 2012 | 10:39 PM
drmix's Avatar
Heres some part numbers if you need them.
ITR throttle cable: 17910-ST7-R01
ITR bracket: 16411-P73-000
Old Dec 28, 2012 | 10:48 PM
Alright thanks ! that clears it up a lot
DC206R
May 6, 2010 09:53 AM
Ej8_KiD
Oct 29, 2009 09:24 PM
lsvtecboi'95
Aug 4, 2007 07:53 PM
drumking15
Apr 10, 2003 06:46 AM
NeXtLeVeL_TyPe_R
Nov 5, 2001 06:04 AM
