Where can I find tachometer wire?
I'm tryna install a shift light in a 2010 Honda Civic Si. Does anyone know if it has a wire from the ecu that has the signal? Thanks in advance for any answers/advice/help!
You say tomato....
The thing blinks around 7,500, goes solid around 8k. Just shift when you see the bloody thing turn on.
If not you're going to have to tap into the Crank sensor wire, and have a light that can read off a crank sensor signal at 12v.
Sir Del Slow
Apr 28, 2003 09:49 PM
crashtest Sonny
Jun 23, 2002 11:22 PM
