gsr ecu
im new with cars and i just got a gsr 97 4 doors from my brother...but the ecu is burnt out and i was wondering is there a specific code ecu im suppose to buy for my gsr or can i just go online and just buy ones for my year?
I took it to a mechanic and he said it was the ecu. He said probly one from the market would cost a good 1600 but im wondering if it has to be a specific code to each ecu for each integ. Because i dont want to buy a ecu that isnt for my integ
What exactly is happening, [or not happening] with the car?
Please don't just say it will not start, try to be specific,
Although ECU/ECMs do go bad, there are 101 other things that could be the problem.
I just don't trust a mechanic that tells you the ECU is the problem and it will cost you 1600 to replace it, as mouab18c1 points out you can probably find one for around $100, a "Computer Brain Box", ECU/ECM, at a PicknPull is only around $30...
At my location... 590-Computer Brain Box Car-$30.99 core $4.99, $1600 is way out of line, it's called gouging, makes me question his diagnosis. 94
From: Pensacola, FL and every Court House in Louisiana
Aren't you able to check for codes with the service port like you can do with OBD1?
Also is it a automatic or manual. The code you are speaking of is P-72. It is the center group of numbers, the group of numbers on the right indicate auto or manual. Mine is a manual obd2a p72.
Just get another p72 obd2a ecu it should be cheap like around 80 bucks from people on craigslist or buy a chipped ecu with a gsr basemap from ebay for like 150 and start tuning. Lol
Can't chip a obd2 like you can a obd1. He would spend 100 just for the conversion harness to swap to obd1 ecu.
ok i saw one on craiglist and the code for the ecu is 37820-p72-A04 970-305765. would this fit on my car? its a manual gsr 4 door 97...i was also wondering is the A04 for the 4th generation of integ? cause mines the third one because its a 97
It'll plug right in. But figure out what shorted the ecu first.
Or like so many others, are you just going to spend money tossing parts at the car and hope it solves your problem, and if it does not work, how will you know if it is another problem or if you just fried your new ECU/ECM??
94
Op I would also advise trying to locate the actual problem so you don't fry another ecu.
The conversion harness for obd2a to obd 1 is about 30 bucks and to my knowledge you can chip a obd2 ecu it's just a little harder and more money there are kits online. He can buy a ecu that's chipped with a harness or make one himself I bought a p28 and chipped it myself for less than 80 bucks.
The purpose of running a modified Honda ecu is so you can have it tuned to your specific motor once you start running aftermarket parts. It's not so you can change your rev limit and add two-step to make it seem like you're benefiting anything.
If you're running only a header, intake and exhaust then a stock ecu will work just fine.
_HANS
Jun 13, 2004 03:33 PM
