92 DA Chassis, 95 GSR Engine Harness. Diagrams?
Old Dec 26, 2012 | 02:04 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default 92 DA Chassis, 95 GSR Engine Harness. Diagrams?
Before you post something useless, I'm aware of the alternative and easier options. I have a full set of extra plugs, plenty of wire, solder, and splices; this project is out of principle.
I have every OEM diagram needed, and with enough time and beer I can do it through old fashioned ingenuity.
BUT, I'm curious if anyone who's wired in a DC/DB engine harness to a DA took the time to document it, and wants to share.
Old Dec 26, 2012 | 02:19 PM
A-stil's Avatar
Default Re: 92 DA Chassis, 95 GSR Engine Harness. Diagrams?
ill ask around but it would be hard and super exspensive, plus there were alot of changes in alot of the electronics/emissions thats where youll have the most trouble
Old Dec 26, 2012 | 05:16 PM
HondaPartsHero's Avatar
Technical Hero
The only real differences because both are obd1 are the addition of VTEC, knock, IABs, and map sensor extending. Just use the harness that's in there and do the above.
Old Dec 28, 2012 | 02:51 PM
I'm Huge In Japan
It shouldn't be expensive, I have a full set of extra pins and plugs, it's just a matter of rewiring, splicing and swapping pins. OBD1 integras operate the same, just from different locations. But thank you for asking around, it'd be a huge time saver.
Sorry if I wasn't clear, I am aware of the easier options, and don't need any useless suggestions. I'm intentionally doing it the hard way.
Old Jan 2, 2013 | 12:13 PM
I'm Huge In Japan
bumpers, show me some love HT
Old Jan 2, 2013 | 12:30 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Doubt you will be getting much help telling those that try, that you don't need their useless suggestions!!!!
Why complicate things?
Old Jan 2, 2013 | 01:39 PM
Technical Hero
He doesn't need your useless questions and advice
Old Jan 2, 2013 | 01:41 PM
Technical Hero
In that case use an 92 Mustang wiring harness and do a carburetor kit conversion and convert that to steam powered. You can get wagon wheels for a discount now as well and draw your car by horse.
speed_demon018
Jan 30, 2013 07:58 AM
Crazed-Sol
Aug 26, 2009 03:18 PM
DB2NineDuece
Dec 6, 2008 09:07 PM
konidude
Jan 1, 2006 03:46 PM
