JDM EP3R k20 high idle
Old Dec 25, 2012 | 01:03 AM
lemmiwinks's Avatar
Default JDM EP3R k20 high idle
Hey all,
I've a JDM EP3R k20 that is experiencing some idling issues. Originally it was idle surging which was rectified with an IACV clean and TPS sensor adjustment to .50v - .51v. Which made the car idle steadily at 1k rpm. A couple days later I took the car for a short drive and while I pulled over to have a smoke I noticed that the idle increased as the car was idling. (2k rpm)
Drove home, checked TPS voltages again. 0.50v - 0.52v which seems ok still. Idles around 1.7k rpm at the moment but doesn't fluctuate, so I'm assuming the IACV is fine too. Bled the coolant again, and problem still persists.
I've noticed that the coolant temp gauge on the cluster doesn't reach the middle. Is the middle the optimum temperature? (I'm not too sure as I recently bought this car).
What could be the problem?
Old Dec 25, 2012 | 05:14 PM
lemmiwinks's Avatar
Default Re: JDM EP3R k20 high idle
Started the car from cold today with the battery disconnected overnight. Once the thermostat opens up to cool the engine, that is when the rev's idle at around 1700-1800. When the thermostat closes up again, the rev's stay at that rate and don't drop back down to 1k rpm...
Old Dec 26, 2012 | 08:54 AM
paqman's Avatar
What's the coolant level at?
Old Dec 28, 2012 | 07:46 PM
lemmiwinks's Avatar
coolant level in radiator is full, and bled. reservoir is 3/4 full
Old Dec 30, 2012 | 01:00 AM
lemmiwinks's Avatar
I've just followed some troubleshooting guides with the service manual which has led me to an open wire between the ECM/PCM connector and the ac clutch relay in the hood fuse box.
To repair this, is it as simple as running another wire from the ECM/PCM connector straight to the ac clutch relay wire behind the fuse box?
Old Dec 30, 2012 | 06:06 AM
paqman's Avatar
You can use a "jumper wire" to confirm. Back probe both connectors with small paper clips. Then wrap each end of an electrical wire to the clips and test. If it doesn't change, there's no need to install.
Old Dec 30, 2012 | 08:01 AM
lemmiwinks's Avatar
Sweet. thanks, just wanted to confirm, just incase i blow anything.
decon
Dec 19, 2012 07:57 PM
Inextricabledrvr
Feb 7, 2012 08:31 AM
dohc_profile
Feb 17, 2009 09:19 AM
byronl
Jun 14, 2006 08:26 PM
