SiR F20b head swap on F20a dohc block
Old Dec 24, 2012 | 01:30 PM
Shazi All Motor's Avatar
Default SiR F20b head swap on F20a dohc block
hey guys, i have a complete sir F20b head put down with timing belt, headgasket, head bolts, cams w/ camgears and everything sitting. my friend has a dohc F20a in his ascot and would like to know if my sir head will work on his F20a block so that he can go vtec.
plZ do not tell me to buy a complete f20b engine if the swap can work just plz guide me as to what will be needed to do this Frankenstein if it is possible and if it is a direct bolt on.
Old Dec 24, 2012 | 08:16 PM
v4lu3s's Avatar
RTFM
Default Re: SiR F20b head swap on F20a dohc block
you will have to sort of follow the guidelines for putting an h head on an f block but it may not be perfect since the f20a and f20b is not common in the US where the headswaps have been most documented.
Shazi All Motor
Mar 10, 2013 02:42 PM
matalatto
Dec 4, 2008 07:07 PM
biggnubbs
Nov 2, 2005 09:38 AM
quoney2000
Apr 7, 2004 09:08 PM
driftkid01
Apr 3, 2004 06:15 PM
