*PICS* Can I delete these A/C related relays on huge wiring harness
Hey guys, so my a/c compressor stopped working mid summer, so I took the a/c compressor and all the hardlines out just now. But there also is a huge eye sore of a wiring harness aswell and some relays mounted behind the passenger headlight that Im hoping to delete aswell.
My questions is if I can delete the wiring harness AND relays, and that one ground by the relays, without affecting any other systems of the car.
The relays and ground
Where one side of the narness connects in the the fusebox, just a simple pull connector no fuse it seems
Then the harness goes across the front of the car and into the firewall here, I didnt follow it through the firewall, Im assuming there is a simple connector on the other side somewhere?? To snowy to get on my back in the driveway
Has anyone deleted this successfully?
Ya, you can remove it without issues. Please don't cut it!! There are two more plugs inside the cabin. One goes to the evaporator and one on the main harness. IMO, get a new compressor and keep the AC!! You can also remove the evap and put a delete where it goes if you really want to remove the whole thing.
streetracerof06
Sep 2, 2005 07:16 AM
