new to me 03 civic Si
Old Dec 24, 2012 | 04:56 AM
darrell111's Avatar
Default new to me 03 civic Si
I bought the car from a scrap yard and know nothing of the previous owner, and want to work out a few bugs it has.
P1166 code I have found searching on google. 02 sensor or wiring issue.
Tripp odometer doesnt work, so I can't get the maint. req. light to go out.
Door locks dont work, I hear them trying to do something but they dont actually lock. The passanger door doesnt do anything now. It used to try.
It has 184K miles. What should i look for and are there any other problems I should look for?
Oh and did these come with remote start? If so how can I tell if this one is equipped with it?
Old Dec 24, 2012 | 06:35 AM
toyomatt84's Avatar
Sanji
Default Re: new to me 03 civic Si
Remote start wasn't offered on Civics.
Old Dec 24, 2012 | 06:16 PM
darrell111's Avatar
is the trip odometer a common issue?
What about the door locks?
I tried searching and cant seem to find anything on these
Old Dec 26, 2012 | 09:24 AM
slo_hatch's Avatar
The door lock sounds like a door lock actuator. very common on some Hondas. and I haven't seen an ep3 do the trip odometer, but I have seen some 01-05 ex/lx cars do it. My advise, fix the door lock actuator, and get a new cluster bc if I remember correctly, that's the only way to fix the trip.
Old Jan 2, 2013 | 10:03 PM
jdmdomo's Avatar
On my odometer , works fine , I just hit 179, Xxx miles on it . on the original engine .
And still take me to work everyday .,
I'm oready have on the side a k20a2 swap , But all I need it's time to replace it .
Old Jan 5, 2013 | 07:15 AM
OH10_BMC's Avatar
I have owned two EP3's and never had an odometer issue. I would assume, like the others, that a new cluster would be needed to fix this.
Door lock actuators are very common to fail in the vehicles. There are a few DIY's floating around the internet that can assist you in getting those fixed.
Old Jan 6, 2013 | 01:37 PM
darrell111's Avatar
fixed the trip swithch, someone had the cluster apart before and didnt have it back together all the way. the push rod wasnt hitting the button/switch.
got to check out the door actuator. its getting signal from the switch. not sure how to get the actuator out. Is it connected to the door latch as a system or is it separate?
also looking for a cheap remote entry for the car? other than e-bay wheres a good source for them
Old Jan 7, 2013 | 07:42 AM
OH10_BMC's Avatar
Door Lock Actuator DIY
http://www.ephatch.com/forum/showthr...ight=door+lock
Unless you want to get an OEM key FOB from the dealer, I say get one from ebay. Be sure you get the right part number though.
flat6turboGT1
Sep 7, 2009 01:02 AM
jxhxb
Jan 31, 2008 10:14 PM
jca1972
Jul 6, 2007 12:05 PM
shibbywhitedude
Jan 8, 2007 08:04 PM
rtcpenguin
Honda Civic (2001 - 2005)
10
Aug 3, 2006 07:39 PM
