what axles can i use on a b16 eg with sk7 shaft?
Hey I have a ej1 with a b16 swap and just recently my driver side axle fell apart at the outer side. When I looked up what axles I can use every post online say I can use 99-00 axles or 94-01 Integra axles. So picked up a set of si axles and when I took out my driver side axle the part that goes in the intermediate shaft it has splines going all the way down to the end and the si axles have the splines going half way down. Can I still use the axles ? Plus I found out that the intermediate shaft I have is probably a sk7 because it Has a female end of the shaft. So do I have to get a new axle? If I do what kind do I need thanks
