checked compression, check it out!!
Old Oct 19, 2002 | 06:04 PM
stupidfast's Avatar
Default checked compression, check it out!!
My car is a b18c1 with us type r pistons.. So i think the compression is 10.8 to 1. My numbers were 200 in all four cylinders.. Does this sound a little low??
Old Oct 19, 2002 | 06:38 PM
3rdGteg's Avatar
Default Re: checked compression, check it out!! (stupidfast69)
If it's 200 across the board then you're cool. The dynamic compression is not related to static compression.
Old Oct 19, 2002 | 07:04 PM
boonacka's Avatar
Default Re: checked compression, check it out!! (3rdGteg)
so does that mean its ok that the compression might be a little low as long as its an equal compression in each cylinder? did i make sense..
Old Oct 19, 2002 | 08:18 PM
3rdGteg's Avatar
Default Re: checked compression, check it out!! (boonacka)
That compression result is not low for his vehicle. And yes, it's best when the cylinder's compression does not vary much. You can have a maximum variance of 25psi and normal should be around 125-200psi per cylinder according to a service manual at work.
Old Oct 19, 2002 | 08:30 PM
tonyxcom's Avatar
I have been told that anything 200 or over is acceptable.
More important is that the values for each cylnders are equal, or pretty close to it.
200 - 205 - 203 - 199 = OK
220 - 199 - 219 - 221 = Problem in Cylnder #2
Old Oct 20, 2002 | 03:50 PM
stupidfast's Avatar
Default Re: checked compression, check it out!! (tonyxcom)
i checked it again today when the motor was warm and it did 215 in all four cylinders.. That seems a little better for 10.8 to 1 compression..
ef_si
Jul 25, 2013 02:09 PM
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
builtprelude
Jan 22, 2004 10:49 PM
