Extended bolts needed for BWR subframe and beaks tie bar?
Hey, before the flaming about unnecessary suspension parts begins, I will clarify that this tie bar is solely for bling factor. But my question is, does BWR provide long enough bolts with their subframe brace that a beaks tie bar will fit without error? Or should I order a asr extended bolt kit off JHP? Just curious before I blow $25 on 2 bolts..
i got some super long ones online that are for a polaris something or another https://honda-tech.com/forums/showth...705824&page=11, as long as your not running the s2 lower arm bar like me with all the other **** i have ASR has bolts that should work for you
ZipTieGUy
Mar 5, 2006 09:47 PM
SD_EM1
Jun 10, 2004 11:28 PM
