99gsr ABS converting to 5 lug jdm ABS
I red few topics but they dont say what exactly needs to be done
heres what i gathered so far
Need rear trailing arm for 5 lug
Since gsr is also ABS i can keep the master cylinder and abs pump and just replace the abs computer to ITR
98 jdm itr came with 36mm axles correct?
https://honda-tech.com/forums/suspension-brakes-54/5-lug-conversion-using-4-lug-spindles-front-rear-1978033/
heres to help you out with 5 lug..
or you could search for my version (the start of a poor mans 5 lug swap)
which removes the need for tack welding the nut.
You shouldnt have to change the abs computer or anything related to abs.. if your vehicle has it aleady.
Propulsion
Apr 29, 2003 05:55 AM
