100k mile GS-R dyno...
On Friday night (10/18), I turned the 100k mile mark on my GS-R. On Saturday, I dynoed it to see how the engine is doing (compression test coming soon as well). Here you go...
All 3 at once...
The odometer...(cheap disposable camera used, I hate those!)
Getting ready to run...
Doing a pull...
Things to note...
The engine was misfiring, new wires, cap, rotor are needed, badly. As for the mods...pretty basic stuff:
-stock exhaust w/DC 4-2-1 ceramic piece of junk
-old AEM CAI
-Jun flywheel/clutchmasters stage 1 clutch
-most of my money is in suspension
...not bad for a 100k mile beast ehh?
EDIT: I changed website servers, needed to update picture links.
[Modified by cheezthis, 2:03 PM 12/5/2002]
All 3 at once...
Doing a pull...
Things to note...
-old AEM CAI
what happened between the red dyno graph and the final one? looks like you lost a lot of midrange for the final run..
Still running strong....
Did you change your Wires and Distrib/Cap? Did it get rid of the cylinder misfire?
I'm having the same problem.
not bad at all. should of done a pull w/o ps belt......
what upgrades to u plan?
get some ITR cams, cam gears, JDM 4-1 header and free up that exhaust and u should hit 170 no problem.
stick who now has 109k on his GSR
As for the exhaust system, I haven't decided what I'll get yet, but JDM sized 4-1 header will be involved.
*EDITED because I can't type today.
[Modified by cheezthis, 1:01 PM 10/20/2002]
There was no tuning involved, these were just 3 runs. The curve dropped because the temperature rised the hotter the engine got. All 3 runs were done in less than 5 minutes...total. So the engine, did have a lot of time to cool...which is why the torque dropped.
sweet, kinda gives me an idea of what my car could pull. I would like to make a pull just to know, though. My car has 125K now, but it runs like a top. No midfires, pinging or anything.
All I have is K&N filter in stock box w/ DIY icebox intake. The rest is suspension.
actually the JDM header w/ hi flow cat and either ITR exhaust or bigger like SMSP exhaust (flows very well) along w/ cams, cam gears, and vtec controller will give u some decent power.
do everything at once and also get both cams (intake/exh) so u dont have to go back later and put in the exhaust cam like me
looks good man, where did you go? Looks like AMS
Stick: Yeah, I plan on doing both at the same time...all the internals will be done at the same time. I have to make it easy on myself somehow
