Headlight/high beam and corner signal light harness
My teg got stolen and they cut off all the harness. You guys know the part number or any website I can buy them from? Or if you guys have'em pm me or post on here. Need them asap before this coming week ends, gotta get back to work and I need them to drive early in the morning.
Car is a 96 teg db7 but have on a 98+ front bumper. Would the harness be different?
Check your local bone yards, [PicknPull], harness should be the same although the last diget in part number is differant for 96 and 98, your car is a 96 so go with it.
It also looks like it is two harnesses...
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I would find a G3 and clip off the part of the harnesses you need and solder/shrink tube them to yours, if you get lucky, you may find undamaged ones and get them all the way to a plug. 94
Ive only been to one junkyard in MN and i didnt see any integra at all. I doubt i can find it at a junkyard. Saw some with pig tail on ebay. Think they good? Has anyome tried ebay ones?
I see you do not have a PicknPull in MN, but there must be more then one bone yard in your area, if not, so sad.
The 94 that was put in the yard on 12/07/2012 at our PicknPull ...
http://www.picknpull.com/check_inven...ra&Distance=20
was complete, and stock, in fact it ran, but is in very poor shape, ran like **** also.
I may be convinced, [paid] to go out there and if the harnesses are there, and in good shape, pull them, send them to you.
650C Wire Harness No Acc (Lrg) Car $36.99
650B Wire Harness No Acc (Med) Car $25.99
650A Wire Harness No Acc (Sml) Car $13.49
I do not know, [at this point] if it is in one harness or two harnesses, maybe a left and right "sub harness" or what they will cost but the above are Kelowna prices, to give you an idea.
Don't worry, it's no big deal weather wise, I know you are in MN, I spent 30 years in Winnipeg Man. and I understand "stupid cold" but here in the Okanagan valley, [Kelowna B.C.] at this time of year it is around 0 degrees C during the day and maybe sunny.94
Ill think about it. Ill try to see if theres any more junk in MN and try to contact them if they got any. If not ill check with my buddy, in Cali which is where im from, to see if he can go out to the junk. If no luck. Ill pm you. Thanks buddy!
98DC4
Feb 8, 2009 03:47 PM
tegsallgood
Oct 26, 2004 04:49 PM
