2001 type r wont start
Old Dec 21, 2012 | 07:14 AM
PeterVSays's Avatar
Default 2001 type r wont start
started up my car let it warm for 10 mins. drove it down the street, starting bogging. then died. tried starting it, it cranks but it wont start and sometimes it wont even crank. no CEL or anything. help anyone?
Old Dec 21, 2012 | 07:26 AM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: 2001 type r wont start
Is the car off the street?
If not, get it to your garage asap.
First, you need to check the basics.
Is the air filter clogged?
Do you have fuel pressure?
Does it have spark?
Is there enough compression to start?
After that, check... aaaaaa **** it... just check you battery grounds. It sounds like your starter might be taking a crap. Get the engine to crank over first and we'll go from there. Also, check for a CEL at key on. Does it come on, you hear the fuel pump come on and then goes off?
Old Dec 21, 2012 | 07:53 AM
PeterVSays's Avatar
Does it have spark?
everything is there, it cranks up fine now. just no sparks. could it be the immobilizer?
Old Dec 21, 2012 | 08:03 AM
Dos Pupusas
Is your green key light flashing?
Did the cel go out?
Old Dec 21, 2012 | 08:05 AM
Chuonthis069's Avatar
Check to see if any of the spark plug wires came loose from the dizzy.
Old Dec 21, 2012 | 08:29 AM
PeterVSays's Avatar
check that. all plugs are flushed in. we stuck a screwdriver in the spark end and it didnt spark.
Old Dec 21, 2012 | 08:30 AM
PeterVSays's Avatar
Did the cel go out?
cel went out and the green light went out too. i think... i cant remember. i have to put back in my distributor and try it again. try taking the distributor to the the local Acura dealership and they were gonna rip me off by having me take in my car. lol
EDIT: the CEL and the Green light both went out.
Old Dec 21, 2012 | 08:40 AM
Dos Pupusas
Can you check the voltage to the dizzy?
Do you have access to a multimeter?
Once you check that, we can condemn your dizzy.
Hear:
Check your dizzy using the colors on the right (OBD2)
Old Dec 21, 2012 | 08:45 AM
PeterVSays's Avatar
Hear:
how do you do that?>
Old Dec 21, 2012 | 09:02 AM
Dos Pupusas
Unplug your dizzy.
With someone cranking the engine over, check your positive (+) wires from the diagram above. See what they put out. I think some might be just signals, so you might not see 12V+.
But just to make sure, find the heavy gauge Blk/Ylw wire. That is you ignition coil (+). Measure that with your multimeter. If it shows 12v+ while cranking, then it usually means your ignition coil took a dump. Which you can buy and replace, instead of buying a whole dizzy.
Old Dec 21, 2012 | 09:06 AM
Dos Pupusas
Better with pics...
Old Dec 21, 2012 | 09:55 AM
Bowman's Avatar
check dizzy fo sho!
Old Dec 21, 2012 | 10:10 AM
01typerboi's Avatar
make sure the timing belt didnt break
Old Dec 21, 2012 | 11:29 PM
PeterVSays's Avatar
nevermind i fixed it. it was my coil inside the distributor.
Old Dec 22, 2012 | 01:26 AM
01typerboi's Avatar
cool. atleast it was an easy fix. glad to hear
Old Dec 23, 2012 | 10:00 PM
mr_munro's Avatar
99% cause of Honda 'no start' issue
Old Dec 29, 2012 | 08:13 AM
GraphiteAcc0rd's Avatar
Keep a few ignitors and coils around, honda's like to eat them!
Old Dec 29, 2012 | 11:22 AM
PeterVSays's Avatar
might be installing a MSD coil soon if that keeps up.
Old Dec 29, 2012 | 10:51 PM
mr_munro's Avatar
Don;t waste your money. OEM is more than enough.
Impulsed
May 31, 2021 07:06 PM
nate10498
14
Jan 18, 2009 08:56 PM
idylan123
Mar 18, 2008 05:06 PM
draw
20
Nov 22, 2004 08:33 AM
posterchild
Jun 26, 2004 02:09 PM
