Rattle coming from distributor...
Old Oct 19, 2002 | 04:57 PM
Rory Breaker's Avatar
Default Rattle coming from distributor...
What does that mean? I have a rattle coming from my distributor...like shaking a bb in a can real fast.
Is my rotor toast? What would this indicate?
Old Oct 19, 2002 | 05:02 PM
EP3_05's Avatar
Default Re: Rattle coming from distributor... (newgsrdriver)
I would pop the dist. cap off and make sure the screw that holds the rotor on the shaft has not come loose.
Old Oct 19, 2002 | 05:31 PM
Shark Tank's Avatar
Default Re: Rattle coming from distributor... (91civic)
how old is your distributor? that sound usually is the start of the end for the dist.
Old Oct 19, 2002 | 05:49 PM
Default Re: Rattle coming from distributor... (CART fan)
Ill check that screw tomorrow...thats what I was thinking as well. Either that or the rotor was somehow damaged.
The distributor has about 95k on it now.
Old Oct 19, 2002 | 06:40 PM
BreakStuff's Avatar
New User
easy enough diagnosis...
Remove the distributor and see if you can "wobble" the shaft...
If so...time for a new distributor assembly... (approx $75 new)....
Old Oct 19, 2002 | 07:12 PM
TREVER's Avatar
Default Re: Rattle coming from distributor... (BreakStuff)
$75 new, Where from?
Old Oct 20, 2002 | 05:18 AM
What is this doing for me now...hurting performance/mileage in any way?
Old Oct 20, 2002 | 05:04 PM
TREVER's Avatar
The bushing is wasted. It will soon create enough heat to either melt your rotor off or damage your position sensors. The car will stall and not restart. You need to buy a dist. sub assembly from the dealer. I recomend you use honda parts because most aftermarket or rebuilds don't last long. $75 is wrong they run 300-400 if I remember right.
Old Oct 20, 2002 | 07:37 PM
Default Re: Rattle coming from distributor... (TREVER)
This is unrepairable I guess if I took it apart?
Time to crack open my helms to understand what exactly is busted
Couldnt I just snag a used distributor, or does the problem go further than that?
Old Oct 21, 2002 | 04:18 PM
TREVER's Avatar
Sure you could by a used one. If you unbolt the dist and twist it where the cam does you will see quick whats wrong with it.
Old Oct 21, 2002 | 05:12 PM
Quick 200k Mile Motor's Avatar
sshiet! And I just got a used dizzy from a 95' GSR.
I thought it was only the 92'GSR dizzy that is known to go bad.
Old Oct 21, 2002 | 05:45 PM
BreakStuff's Avatar
New User
Any Honda/Acura dealer... Thats the cost of the distributor body and doesnt include a coil, ignitor, cap or rotor...
Old Oct 21, 2002 | 05:49 PM
TREVER's Avatar
all honda acura DIZZY? wear out. I guess all of those distributors I sold during the four years I worked at the Honda dealer were horribly over priced. Or maybe someone is talking out of there ***.
Old Nov 17, 2002 | 02:45 PM
thecorey's Avatar
which distributor do you buy for a odb0 b16?
Old Nov 17, 2002 | 04:55 PM
Tweakmeister's Avatar
Default Re: Rattle coming from distributor... (thekori)
we had this sound on my '96.
basically the shop (I couldn't work on cars back then ) tested the bearing temp. and said it was about to roast.
they paid something like $250 for a whole new assembly because you can't buy just the part from Acura.
you should be able to do better.....but verify that this is the case.
Old Feb 24, 2003 | 11:35 AM
nardeezy's Avatar
Default Re: Rattle coming from distributor... (Tweakmeister)
I have this same exact problem on my 97 LS. I bought a used 99 LS distributor and swapped mine out. I still get the same rattle, nothing seems loose on my old distributor, help!
Old Feb 24, 2003 | 11:36 AM
nardeezy's Avatar
Old Feb 24, 2003 | 03:20 PM
Default Re: Rattle coming from distributor... (nardeezy)
you swapped the entire thing out?
sure it's not your injectors ticking?
Old Feb 24, 2003 | 03:39 PM
altoid's Avatar
dude i get the same sound on my zc, only when i first start up and my car isn't warm....it sounds like its only coming from the belts though...still the dizzy?
Old Feb 24, 2003 | 03:45 PM
sivik2nr's Avatar
I have that same noise from mine, and yeah it's coming from the distributor. So I can unbolt it and then if that little thing that spins, moves at all ( besides rotating ) , wobbles, jiggles, whatever, then I'm probably gonna need a new distrib?
When I got the motor, one of the CELs was a positioning sensor,( the one IN the distributor ) so I just took another apart and it had the same number on it, and it seems to work fine. I know that the rattling is there though but no CEL.
I'm also getting a oil leak there, aroung that area by the cam seals, distrib, vtec solenoid... Could this be my prob?
Old Feb 24, 2003 | 08:09 PM
3rdGteg's Avatar
Default Re: Rattle coming from distributor... (sivik2nr)
me too; it seems as if the oil is coming out from underneath my distributer only though!?
Old Mar 3, 2003 | 12:42 PM
thecorey's Avatar
sounds like a bearing is out...it happened to me
Old Mar 3, 2003 | 02:25 PM
sivik2nr's Avatar
Yeah, i'm just kinda waiting for it warm up a little bit here. Last week was getting pretty nice, but I had to work so i had no time. But Once it gets a little warmer, I will invesigate further. I will unbolt it and take a short vid of it and post it and see if it's the same problem everyone else is having.
mellowman164
Jan 12, 2014 10:59 PM
LoseRPunKx182
Jan 19, 2006 02:01 PM
trooper0641
Jul 9, 2005 12:22 PM
DCtwoR
Aug 8, 2002 01:34 PM
KJ
Jul 30, 2001 07:54 AM
