knock sensor on harness??? and a6 to a11 swap
Old Dec 20, 2012 | 11:44 AM
Crxh22ajdm's Avatar
Default knock sensor on harness??? and a6 to a11 swap
ok I have a 97 honda accord ex 5spd, I swap and obd1 h22a, well im having some trible with the wiring, well only on ecu pinouts, on my stock Uncut harness on the ecu, its missing the knock wiring, on other honda pinouts is on D6, but on my stock harness does not come in there, my old engine came with a knock sensor, also in the engine wiring, I can just make a direct wire swap buts I know there should be a knock sensor wire on my ecu harness so I can eassily make a bypass swap in wires but I dont know the pin # ON my stock harness ON OTHER HONDAS IS ON D6. Also do I still have to make the Famous pin swap A6 to A11 on my year CD5 97
Old Dec 20, 2012 | 11:51 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: knock sensor on harness??? and a6 to a11 swap
Be honest, did you actually read any of the guides? The Accord FAQ had quite a few, so does Google.
Here's one,
http://www.superhonda.com/forum/f13/...accord-164067/
-If your car didn’t come with VTEC, you’ll need to add the wiring for the air intake bypass (AIB), knock sensor, VTEC oil pressure sensor and VTEC solenoid. IF your car was EX, you will only need to add wiring for the IAB and the knock sensor.
Old Dec 21, 2012 | 01:55 AM
holmesnmanny's Avatar
How many threads are you going to make ?
joshuad86
Aug 16, 2017 09:17 PM
bwfisherman09
Oct 17, 2012 05:48 PM
hondakevin21
Jun 1, 2007 06:00 AM
. o 69 o .
Apr 19, 2004 04:26 PM
g's integ
May 3, 2002 08:41 AM
