Bleeding coolant system with rad cap off, blowing out radiator
I tried bleeding the cooling system, with the engine warm and the cap off. When I loosen bleed valve it started sucking air and spraying coolant out radiator cap. I also noticed after I turn off car and start again the hoses collapse????
Cant see water pump leaking, clogged system maybe? Where could vacuum pressure come from? Intake manifold gasket?
robbys89
May 13, 2009 12:02 PM
