92 integra ls
Old Dec 19, 2012 | 05:11 PM
Luillo's Avatar
Default 92 integra ls
Hi guys I just bought a 1992 integra. I'm doing and engine swap to a B20B. I see that on the b18a1 is a sensor next to the oil pressure sensor by the oil filter and is another sensor next to it and the B20B doesn't have one there also I notice that the water outlet of the B18a1 has another water tube that the B20b doesn't have. The b18a1 also has another little black box in the block under the intake connected to a Pcv valve on the intake. Do I have to transfer the water outlet housing completely or I can eliminate that water hose? Do I have to also adapt that sensor next to the oil pressure sensor?
Please anybody can help me out with this.
Old Dec 20, 2012 | 08:45 PM
jh4dbgs's Avatar
10 Year Member
Default Re: 92 integra ls
I did some googlein' for you and found a write up that seems pretty up to par. Check it out and see if it helps answer your questions.
http://forums.g2ic.com/showthread.ph...-into-92-93-LS
Old Jan 18, 2013 | 03:40 PM
Luillo's Avatar
Thank you for the information.
jdm j
Honda S2000
Feb 17, 2008 12:25 PM
tdizz07
May 9, 2007 10:13 AM
wicked2night
23
Apr 29, 2007 11:32 AM
a1320addict
Jun 4, 2006 06:07 PM
VTECAcuraGSR
10
Jun 29, 2003 09:02 PM
