HUGE ACURA AND HONDA GARAGE SALE OVER 100 PICTURES OF EVERYTHING
EVERYTHING on this list has a picture next to it.
I'm cleaning out my garage. I have accumulated a bunch of parts in the past few years that are taking up space. Everything must go. Accepting all reasonable offers.
All parts are to be picked up in Essex, Maryland. Google map zip code 21221 to know exactly where that is.
I have taken the past week to put this together. So please read everything before you contact me. If I have not listed what it came off of I just don't remember at this point OR it can be used for several applications. It is your job to research. I have mainly parted out Honda Civics/Del Sol and Acura Integras.
CALL/TEXT: 443-564-9376 PLEASE DO NOT CONTACT AFTER MIDNIGHT!
Please be SPECIFIC when you contact me, especially texting. I have too much stuff for different vehicles to try to figure out what YOU want.
Anything that is listed is still available. If it has sold I will delete it. No need to ask if I still have it. I will be adding more parts as I get the time to inventory them and take more pictures. So please check back. I DO NOT HAVE ANYTHING FOR ANY OTHER MODELS!
1999 2000 CIVIC SI EM1 PARTS
1999 civic si em1 front strut bar image
b16 AC compressor image
b16 starter image
B16 starter #2 image
civic SI emergency brake handle image
civic SI battery tray electron blue image
1990 1991 1992 1993 ACURA INTEGRA PARTS
da integra cluster 150k image
da integra cluster 167k image
da integra alternator (needs rebuild) image
da integra climate control w cables and harness image
da integra glove box image
da integra BNIB rear sway bar image
da integra window regulator image
da integra caliper image
da integra master cylinder image
da integra bumper corner light image
da integra rear speaker mounts/grills image
da integra caplier image
da integra drivers side spindle with hub image
da integra coupe rear filler piece image
da integra blower box (no motor) image1 image2
da integra radio trim panel w/ ashtray image
da integra heater box / blower motor (bent inlet and outlet pipe on HC) image
da intgera gauge bezel image
da integra starter image
da integra wiper motor image
da integra rear cargo cover X2 image1 image2
1994 1995 1996 1997 ACURA INTEGRA PARTS
dc integra wiper motor arms image
dc integra airbag brown image
dc integra gauge bezel image
dc integra cluster 195k image
dc integra hatch struts image
dc integra wiper arms image
dc integra front strut bar image
dc integra rear wiper motor image
dc integra wiper cowl image
dc integra battery tray image
dc integra rear sway bar image
dc integra coupe headliner image
dc integra sunroof assembly with glass image
dc integra washer wiper fluid reservior image
dc integra SRS control module image
dc integra rear right cargo panel (cracked) image1 image2
dc integra coupe black carpet (no rips or tears) image
dc integra rear cargo trunk carpet right side image
dc integra rear latch cover trim image
dc integra 1994 GSR complete interior wiring harness (from underhood fuse box to tail lights) image
1994 1995 1996 1997 HONDA ACCORD PARTS
accord power steering pump image
1988 1989 1990 1991 HONDA CIVIC PARTS
ef civic dual point engine harness image
ef civic antenna image
ef gauge cluster no tach 243k image
ef dual point intake manifold #1 image
ef dual point intake manifold #2 image
1992 1993 1994 1995 HONDA CIVIC PARTS
eg civic hood release cable image
eg civic coupe right rear panel image
eg civic dash with clear MD title image
eg civic drivers side power inner door panel image
eg civic/ del sol half radiator w/ fan overflow & hoses image
eg civic shift linkage image
eg civic seat rail image
eg civic gauge cluster auto 198k image
eg civic wiper cowl image
eg civic wiper motor and rods image
eg civic b series rear t bracket image
eg civic clutch master cylinder and reservior image
eg civic bottom dash cover image
eg civic center console e brake image
eg civic center console ashtray cigarette lighter image
1996 1997 1998 1999 2000 HONDA CIVIC PARTS
ek civic gauge cluster bezel image
ek civic coupe/hatchback right speaker grill image
ek civic steering cover cover image
ek civic distributor image
ek civic manual cluster no tach 68k image
ek civic driver side door panel w/ blaupunkt components w. crossover image
ek civic door sill image
ek civic sunroof assembly w/ motor (no glass) image
1993 1994 1995 1996 1997 HONDA DEL SOL PARTS
del sol Center Console w/ shift boot image
del sol glove box image
del sol rear speaker mounts image
del sol gauge cluster 222k image
del sol gauge bezel X2 image
del sol gauge cluster 168k image
del sol exhaust with catalytic converter (2 bottom pipes in picture) image
del sol d series shift linkage image
MISCELLANEOUS PARTS
civic combination switch image
shift boot blk/red stitching image
obd1 integra engine harness non vtec image
obd1 civic engine harness non vtec image
viper 500 alarm unit image1, image2
pilot steering wheel image
automate model 3 alarm image
ecu plugs/ connectors image
gray seat belts civic or integra image
megan racing bars for eg or dc image
obd0 distributor no cap image
obd2 distributor image
civic speaker brackets image
b and d series AXLES!!! image
ac condensor image
engine mounts and rear brakets image
shift linkage image
alternator image
b18 flex plate image
abs module image
belt control module image
fuse box image
ac lines image
b series intake piping image
a/c compressor mounts image
brake booster image
a/c and radiator fans image1, image 2
b & d series starters image
a/c compressor image
civic 7/8 master cylinder w/ brake booster image
srs ring image
charcoal canisters image
hydro clutch master cylinders image
hood props image
radiator and coolant hoses image
b18 fuel rail image
B18 half shaft image
ignition switch image
under dash fuse box image
rear view mirrors image
p.s pumps image
ac compressor (2) image
hatch struts image
coolant over flow tanks image
pedal assemblies for 5 speed conversions image
steering column image
b18 intake manifold image
power steering reservoir image
miscellaneous parts 1 image
ac compressor mounts image
wiper arms image
miscellaneous parts 2 image
miscellaneous battery parts image
scissor jacks image
b series heat shields image
clutch slave cylinders image
b series oem intake tube image
honda and acura computers ECU (check models in picture) image1 image2
D15b7 water pump image
d15b7 alternator image
integra b18 clutch #1 image
integra b18 lightened flywheel image
integra b18 clutch #2 (new) image
d series hyrdo clutch with flywheel image
D15 cylinder head w/ 1 chipped valve image
b and d series stock exhaust manifolds image
steering column covers image
honda under dash fuse box image
d15b7 crank pully and tensioner image
d15b7 shortblock good compression image
7/8 brake master cylinder and brake booster image
b16 starter image
MISCELLANEOUS PARTS
ac condensor image
shift linkage image
alternator image
abs module image
fuse box image
ac lines image
brake booster image
srs ring image
hood props image
b18 fuel rail image
p.s pumps image
hatch struts image
wiper arms image
scissor jacks image
eg civic HR lowering srpings and struts w aftermarket read lower control arms (all sold together)
Price Please.
Thank you
Price Please.
Thank you
eg civic power steering rack SOLD
eg civic steering wheel SOLD
eg civic brake rotors SOLD
ef civic cable transmission SOLD
ef civic rear cargo cover SOLD
Sorry if I missed it. I get a lot of texts and several about the same items. I know I responded to at least two different people about those parts. Make me an offer picked up in zip code 21221. I've met up with two people so far today. LMK
