92 Integra LS: Where does this green wire go?
Old Dec 18, 2012 | 11:49 PM
JonTorres23's Avatar
Icon2 92 Integra LS: Where does this green wire go?
Hey guys I recentley bought a 92 integra, owned it for about 2-3 weeks. I recentley did a tune-up and noticed theres a green wire that is just dangling there.
Its a solid green wire, comes through the firewall right next to the brake booster. Its about 3ft long just sitting on the transmission. If you look at the brake booster, its about a 8 o clock where the wire comes through the firewall.
The car is running fine right now. No problems. Been searching for a bit but no luck. Thanks in advanced.
Old Dec 19, 2012 | 05:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: 92 Integra LS: Where does this green wire go?
A picture would help. 94
Old Dec 20, 2012 | 07:07 AM
UndergroundTrev's Avatar
10 Year Member
Is the wire coming out of the factory wire loom or run seperate? Where exactly does it come through the firewall? Is it with the harness or does it come through with the clutch cable or somewhere else? You'll need to determine if it is a factory wire or if it was run by a previous owner for an aftermarket accessory.
Old Dec 20, 2012 | 08:33 PM
jh4dbgs's Avatar
10 Year Member
Being a green wire and if it's not in the harness but ran solo, it might a signal wire for an after market tachometer. Everyone I've seen the signal wire is green.
Old Dec 22, 2012 | 07:56 AM
Micha's Avatar
FAILWGN
Was the motor ever swapped?
Could have been a vtec engagement wire too.
Old Dec 23, 2012 | 09:17 AM
98lude-t's Avatar
Ick I hate that..always hurt when I see a car with the vtec wire to a switch..... Shuttering
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
D16Z6racing
Mar 21, 2007 05:56 AM
5STAR3
Jan 22, 2004 03:47 PM
