Lighting HID/Xenon kits, Retrofits and Associated Topics
93 honda del sol dashlights and ac lights wont come on
Old Dec 18, 2012 | 06:12 PM
Bsha420's Avatar
Icon2 93 honda del sol dashlights and ac lights wont come on
I was changing my dashlights with blue led light bulbs, the new bulbs wouldnt slide into the little black things where the old bulbs use to be, and i needed to sand the inside edges down a little bit so they could slide in, but instead of doing that i thought if i used.. Aluminum Foil i could conduct electricity and the bulbs would be sure to light right up, and i was wrong, so what happened(I only tried one light bulb not all of them at same time) was it caused smoke to appear when i turned on the headlights and i turned the headlights off as soon as i saw the, smoke now my dash lights and ac lights will not come on, and my gear selecter dims out extremely or goes off when i turn on the headlights. My question is what do i need to do to make the light bulbs light it again?
( I already checked the fuses for instrument gauge lights and another fuse under the hood i can't remember what it was right this second, but they both good and not blown)
(Sorry if this was a long read, I felt this was the only way to introduce the problem)
Old Dec 20, 2012 | 08:24 PM
Bsha420's Avatar
Default Re: 93 honda del sol dashlights and ac lights wont come on
I really need help, i need to fix this
Old Dec 23, 2012 | 08:28 AM
stephen.forbes1's Avatar
did you look at all your grounds or get a wiring diagram of the dash has there been any new radios or gauges installed have you checked the fuses
let me know what you have done and i ll try and help you fix it
Old Dec 27, 2012 | 04:19 PM
Bsha420's Avatar
I checked fuses and the radio was replaced before i did this and the lights worked, i have honda civic del sol haynes repair manuel with wiring diagrams, im not sure where the grounds are
Old Jan 2, 2013 | 05:27 PM
ELsol7red's Avatar
I am having the exact same problem. the guy before me replaced head unit. checked all fuses lights on cluster worked for a few weeks. Now i get nothing, thinking about taking the whole dash out???
Old Jan 6, 2013 | 04:04 PM
Bsha420's Avatar
thats what im thinking too but there should be a solution
Old Jan 7, 2013 | 07:52 AM
Bsha420's Avatar
Well i decided that im going to buy a neon kit and just hook it up inside the dash and inside the car then hook it up to the headlight switch and have it turn on when i turn my headlights on
Old Jan 8, 2013 | 04:02 PM
Bsha420's Avatar
But how exactly would i hook it up to the headlight switch, do i hook it up to the fuse?
Han Solo 1
Oct 11, 2014 09:54 AM
OneFire
12
Jun 30, 2011 06:38 PM
simplypinoyy
Jul 12, 2008 11:59 PM
killyourscene
Honda Civic (2006 - 2015)
14
Apr 19, 2007 03:48 PM
Edgemingsr
Aug 18, 2004 11:45 AM
