91 Hatch w/ Z6 Swap: Which OEM front torque mounts to use?
Old Dec 18, 2012 | 05:27 PM
[Ennis_D]'s Avatar
Default 91 Hatch w/ Z6 Swap: Which OEM front torque mounts to use?
After running the swap for a year or so I realize it wouldnt be bad to have the front 2 torque mounts for stability. If I recall correctly, the ones that came with the Z6 swap didnt bolt up correctly so I ditched them.
What are you guys using for OEM lower torque mounts?
TIA guys!!!
Old Dec 18, 2012 | 05:49 PM
video_voide's Avatar
Default Re: 91 Hatch w/ Z6 Swap: Which OEM front torque mounts to use?
I used the front mount that was originally used, meaning I kept my 90 si tranny and mount and mated that to the Z6.
Old Dec 18, 2012 | 05:51 PM
[Ennis_D]'s Avatar
I have a 91 tranny as well. Doesnt look as if there is clearance for the OEM front tranny mount. Maybe I was wrong during the swap bc thats why I ditched it...
Now to search for either it or a replacement I guess...
Old Dec 18, 2012 | 06:07 PM
goldhatch94's Avatar
on the trans there is two bolts that are near the bolt and there is one front mount that bolts to that and then bolts to the front traction bar.
g2turbo
Aug 13, 2017 09:40 AM
frizzle
10
Dec 7, 2009 08:11 PM
(760)doogie
Sep 5, 2008 01:23 PM
Ex-Eg-Driver
Feb 26, 2008 05:35 PM
GetawayInMoscow
Jun 29, 2007 08:42 PM
