Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 Honda accord radio wont turn on
Old Dec 18, 2012 | 05:10 PM
03hondaaccord's Avatar
Default 2003 Honda accord radio wont turn on
My battery had died a few weeks ago. In order to get it to the car shop, we had to jump the car, and for whatever reason the car alarm went off and wouldn't turn off even after starting the ignition. We would have to take out the jumpers, and then it wouldn't start.
Regardless, we ended up getting it started and drove it to the shop, and had a whole new battery put it in, so it should have been fine. The radio needed the code in order to work, and at the time I had lost the paper that I recorded that on.
A few weeks later, and I finally have the code but now the radio doesn't turn on at all. There is nothing on the screen whatsoever, even after pressing the power button, it's just blank. What could have caused this? Is there anything I can do to fix this besides having to bring it into the shop again?
Old Dec 19, 2012 | 07:10 PM
90sedan's Avatar
Default Re: 2003 Honda accord radio wont turn on
You can check for any blown fuses, but the 03 accords are known for having radio display problems. It's common for the circuit board inside the radio to fail and cause the display to go out or be very dim. The radio will still work, music will still play, you just can't see anything on the lcd display.
swennybear23
Nov 19, 2014 05:08 AM
shad295
Oct 28, 2014 10:57 AM
jaed569
May 31, 2009 05:15 PM
GoodEyeSniper
Nov 29, 2008 06:32 PM
JohnP123
Dec 22, 2001 05:11 AM
