HELP ...!!! 99 EK sedan ' daytime running light ' problem ...
Old Dec 18, 2012 | 04:38 PM
emoney803's Avatar
Default HELP ...!!! 99 EK sedan ' daytime running light ' problem ...
I have a 99 Honda Civic DX sedan ... onto the problem ... I have the JDM side marker fairings I wired them up ... worked fine ... So today I wanted to connect the turning signal with the daytime running lights ( I assume that's what they're called ) ... So I attempted to wire them and I guess tapped into the wrong wire ... again assuming blowing the fuse and now my DRL's not working ... but my turning signal headlights and brake lights all work ... so to help me I would need
- preferably a picture on how to set up the side markers so they alternate with the turning signals in the headlights ... or colors of the wires that I must tap into to ...
- Location of the fuse and what amperage fuse goes in ... again preferably a picture ...
Blahhh I should have left em alone lol ...
Old Dec 19, 2012 | 08:10 AM
emoney803's Avatar
Default Re: HELP ...!!! 99 EK sedan ' daytime running light ' problem ...
No one ...???
Old Dec 19, 2012 | 01:37 PM
MercerSX's Avatar
Did you blow the bulbs instead of the fuses?
Old Dec 19, 2012 | 06:55 PM
go-part's Avatar
Yea it sounds as if you blew out the bulbs..
Old Dec 19, 2012 | 07:00 PM
Laughing Man's Avatar
does the day time running lights flash with ur turn signal? Maybe i read wrong but didnt you say you tapped into the turn signal with the wrong wire? or did you leave out that you corrected the wrong wire issue?
crazyowes2000
Honda Civic (2006 - 2015)
Aug 2, 2011 04:35 PM
RedJdmEk4
12
Oct 3, 2009 09:33 PM
Joey B 18C
Feb 18, 2005 06:58 AM
JDM_hotness
Nov 6, 2004 09:01 AM
