Hello fellow Honda Enthusiasts! Code 9 on my 1993 honda accord lx 2.2
Old Dec 18, 2012 | 04:25 PM
BlowmeOffValve's Avatar
Icon2 Hello fellow Honda Enthusiasts! Code 9 on my 1993 honda accord lx 2.2
I shorted the connector under the passenger side glove compartment and saw that the check engine indicator blinked 9 times consecutively. I was wondering how to go about this issue. Last week I changed my motor oil and my transmission fluid (I changed the transmission fluid, drove it a couple hundered miles, then drained it and put new fluid in. DEXIII).
The car starts fine, the gears shift smoothly in traffic, however when I start the car and throw into D4 or reverse it searches for the gear and roughly slams it into place . My car occasionally searches for 3rd or 4th while I'm cruising at low speeds.
This probably comes with the territory of the code 9 and I ask for assistance in what to do to get rid of this code for good and for my car to run as smoothly as it should.
Old Dec 18, 2012 | 07:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Hello fellow Honda Enthusiasts! Code 9 on my 1993 honda accord lx 2.2
Just to clarify, was it the CEL(ECU) light that blinked code 9 or was it the D4(TCU) that blinked code 9?
From the description it almost sounds as though this may be a TCU code 9 issue, which is related to the NC/NM sensors...
Originally Posted by tasauto
The NM or NC speed sensor (code 9) should be within 400-600 Ohms at 20-degrees C. If they are not within spec replace them. If they are within spec check for a possible short to ground but first unplug the harnesses at the TCU.
Two things of note, if the sensors check out its still a good idea to pull them both and make sure they are clear of debris.
Being magnets they attract ferrous material that can build up on the sensor ends and you may begin to lose resolution. This often shows up as random loss or no lockup of converter along with rough or erratic shifting.
When replacing make sure to REPLACE the O rings, once they are disturbed they will not reseal, and will cause for an annoying transmission leak that will cause more shifting issues later.
O rings are part# 91309-PX4-003 (16X2.1) (NOK). They are about two bucks a piece.
If it is the CEL(ECU) light then IIRC that is a crank or cylinder sensor, which IIRC is all in the distributor. Check out the H4A link in my sig for DIY troubleshooting from Tasauto.
Evexon
Sep 17, 2024 09:37 PM
rmiv1985
Jun 27, 2019 04:10 AM
Michelle Hanlon
Mar 29, 2018 05:59 PM
JeffWashington
Dec 12, 2016 10:34 AM
NoHondaexpert
Jan 2, 2014 09:43 AM
