JDM cluster question
Old Oct 19, 2002 | 03:26 PM
SMZ GSR's Avatar
Default JDM cluster question
Hey guys, i drive a 98 GSR and just bought a JDM ITR cluster. I believe the cluster is from a 2000 or 2001 because it has the little key icon and only had 16k KM. Well my friend and i installed it today and both the temp and fuel gauges wouldn't work. the temp stayed at C and the fuel gauge went from me having a 1/4 of a tank to having a full tank. Then we tested the cruise control since the light on that wouldn't go off either. once cruise was engaged the Maint Req light came on.
My question is, could it be messed up because of the different year or is it busted? The guy i bought it from says he has a 94 and says it worked fine.
If it's because of the year, is there anyone in So Cal who would help me by trying it out on their 00/01 ITR. Thanks ahead of time.
Old Oct 19, 2002 | 03:32 PM
Shark Tank's Avatar
Default Re: JDM cluster question (SMZ812)
my guess is busted. i dont know though. i never had problems with my jdm cluster install. i have a 98, cluster is from a 97
Old Oct 19, 2002 | 05:51 PM
Saga's Avatar
From you've said, the cluster you have is most likely off a 96spec JDM ITR, because a 98spec cluster would be a PnP.
To make it work, you can take all 4 gauge faces out from the jdm cluster and swap them with your stock ones. HTH
Old Oct 19, 2002 | 05:56 PM
MiraiZ's Avatar
Default Re: JDM cluster question (Saga)
thats too much work and totally defeats the purpose of having the ITR gauges! Do what I did...I just carefully unscrewed the electonic film on the back and switched it with the oem ones...taking my time, it only took me 20 minutes from start to finish.
Old Oct 19, 2002 | 06:02 PM
Q-OnE's Avatar
Default Re: JDM cluster question (MiraiZ)
i have the 97 spec cluster and everything went in fine. thats pretty weird. i hope its not busted 'cause now you got to go through all the BS in returning it and crap.
Old Oct 19, 2002 | 09:16 PM
Dave-ROR's Avatar
both methods work. how the **** does swapping the jdm cluster's gauges to the usdm cluster housing/motherboard defeat the purpose?
personally I'm wary of fuggen up the motherboard, so I swap the gauges. once the cluster is out it takes a solid 5 minutes with hand tools.. ouch sooo hard and soo much time.
Old Oct 19, 2002 | 09:19 PM
Reid's Avatar
Global Moderator
Default Re: JDM cluster question (Dave-ROR)
I feel the same way.
Also it's much cheaper to fix/replace if you break a part while swapping the gauges, then if you ruin the film.
Old Oct 19, 2002 | 11:54 PM
SMZ GSR's Avatar
Default Re: JDM cluster question (Reid)
thanks for all the info guys! i'm gonna try switching the circuit board Sunday.
-Sergio who's keeping his fingers crossed
Old Oct 20, 2002 | 12:15 AM
MiraiZ's Avatar
sorry my bad...I thought you meant swapping out the faces...as a lot of people have been known to suggest...the film is still a bit easier.
[Modified by MiraiZ, 6:16 PM 10/20/2002]
Old Oct 20, 2002 | 02:19 PM
SMZ GSR's Avatar
Thanks a million guys!!! I tried out switching the green circuit piece and now everything works perfect. My fuel went back down to where it should be, the temp gauge works and the cruise control light isn't stuck on.
Thanks again everyone for your help. Now i don't have to search for a new one and bother the guy i bought this cluster from about returning it (which he was willing to accept)
Old Oct 21, 2002 | 08:52 PM
SMZ GSR's Avatar
Want to thanks everyone again and post up some pics
still haven't put any miles on it...but did let car start to warm up to ensure that temp gauge works.
Old Oct 21, 2002 | 10:57 PM
kappa's Avatar
dang your gauge cluster lights up a hella lot brighter then mine! ... how would i improve the light intensity? is there some sort of bulb i can change or is it the wiring?
Old Apr 29, 2004 | 04:09 PM
Seedc2's Avatar
Default Re: JDM cluster question (kappa)
i was gonna post but I found this thread using the search.
Here is what mine look like http://community.webshots.com/...s.jpg
why is my speedo needle so dim ?
Old Apr 29, 2004 | 04:15 PM
Comp97GSR's Avatar
Default Re: JDM cluster question (kendogg)
I too would like to know, mine seems dimmer. Also, the E/brake symbol is USDM. Did you swap the plastic film for the idiot lights?
Old Apr 29, 2004 | 04:29 PM
Seedc2's Avatar
Default Re: JDM cluster question (Comp97GSR)
hey comp97gsr I was doing archived searches on jdm clusters because I just swapped my jdm cluster gauges into my gsr gauge shell. I recall reading a thread you posted asking if anyone has swapped usdm odometer into a jdm. I completed that today. Its actually quite easy but time consuming. Follow these instructions https://honda-tech.com/zerothread?id=837111
The only part I had a difficult time with was pulling the needle off. I used 2 spoons and pryed them up from each side. I found out after doing a search. Prior to this I had worked on pulling the needle off with my fingers to no avail
Old Apr 29, 2004 | 04:41 PM
Comp97GSR's Avatar
yeah, that was an old thread. I ended up swapping the speedo and changed the gauge face to the jdm one. Worked great, but I ended up geting a USDM R cluster.
Oh and I junked the JDM cluster, it was in bad shape and swapped the needles on the USDM one.
Old Apr 29, 2004 | 04:43 PM
Comp97GSR's Avatar
Oh, and a needle puller is your friend. Definately won't break any needles using one.
Old Apr 29, 2004 | 05:12 PM
MiraiZ's Avatar
to answer the brighter gauge question, you can buy Raybrig white bulbs for gauge clusters. The Spoon clusters come with them and they really make the panel look more vivid. I'm not sure how accessible they are in the States, but I'm sure that you can get them online somewhere.
Old Apr 29, 2004 | 07:45 PM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg &raquo;</TD></TR><TR><TD CLASS="quote">i was gonna post but I found this thread using the search.</TD></TR></TABLE>
Old Apr 29, 2004 | 07:56 PM
B2FiNiTY's Avatar
Are the raybrig white blue coated or clear glass? It's pretty easy to get raybrig products here in the states.
Old Apr 29, 2004 | 08:04 PM
MiraiZ's Avatar
Default Re: JDM cluster question (B2FiNiTY)
they're clear, but the look to have a slightly blue tint to them as well
Old Apr 30, 2004 | 03:35 AM
JDM Factor's Avatar
Just take the film off the back, remember to be careful taking those bulbs out, and placing them in the right order. Next, put your O.E one on. I had the same issue when i ordered my spoon cluster. I have a 2001, and it had a 98 film on the back
Old May 8, 2004 | 02:31 PM
db8-R's Avatar
hey did you guys change the odometer reading when you aswapped the jdm cluster??? if you wanted to know how click on link:
http://clubintegra.net/forum/s...=6412
Old May 8, 2004 | 09:49 PM
SMZ GSR's Avatar
Default Re: JDM cluster question (1993sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir &raquo;</TD></TR><TR><TD CLASS="quote"> i might be wrong but to honda-tech know it alls, im sorry if im giving out the wrong info. just dont verbally kill me for this. cuz im nervous about postin replies you know, i really care what you ******** have to say. yeah right **** you. if you dont like what i got to say, cuz i speak for a lot of people.</TD></TR></TABLE>
What the hell are you rambling about? LOL
This thread is from October of 2002. I realized almost right after buying this cluster (way back then) that it wasn't "real" JDM. Fine by me since I got a good deal
Old May 9, 2004 | 06:04 AM
mikestypeR
Guest
Posts: n/a
i had the same question... is not broken .... for some reason the JDM cluster will not read the fuel .. when i had my gsr i had the same problem
