1999 Civic Si d2b 500whp
I browse this forum a lot but have never posted any pictures of my car aside from my build thread in the drag racing forum. The thread for the build (along with more pictures, dyno videos, etc.) can be found here:
https://honda-tech.com/forums/drag-racing-36/%2A%2Atuner-eddys-d2b-em1-build%2A%2A-go-autoworks-6262-content-3069535/
The car makes just over 500whp @ 28psi on a precision 6262. More boost and some minor changes are coming over these winter months, but cosmetically it's finished.
Here is the complete mod list on the car:
1999 Honda civic si:
VIS Carbon trunk
VIS Carbon lip
New OE front bumper
GO-AUTOWORKS Rear Diffuser
Interior:
REAL CTR Carpet
Interior is dyed black
Black Tweed door panels
JDM CTR Recaro SRD's (black)
No A/C or Heat
AEM A/F gauge
Digital voltmeter
Digital water temp
Apexi boost gauge
Mechanical Oil Psi
The rest of the interior is all in tact, power windows, power sunroof etc, all work.
No Radio
Suspension
Blox Drag coilovers
Blox black rear LCAs
EX front LCAs
New Ball joints, tie rod ends, hub bearings
Energy Suspension front bushing set
Full Race Traction bar
ARP wheel studs
OE Honda pads
Removed Si sway bars, and control arms
Motor:
*This is the ONLY Car w/ this setup. EM1 chassis, D motor, B trans
D16A6 block
Darton Sleeved
75.5mm 9:1 pistons
Scat rods
OEM Honda bearings and pump
ARP headstuds
OEM D16Y8 head gasket (total compression is 9.7:1)
D16Z6 head
Ported and polished
Crower valve springs
Crower retainers
Supertech valves
GO-AUTOWORKS Spec Camshaft by Web Cams
AEM Cam gear
GO-AUTOWORKS Rear block plug
STR (GE) Intake manifold (ported to match head)
GO-AUTOWORKS Thermal intake manifold gasket
68mm Throttle body (intake manifold inlet was ported to match the throttle body)
GE Throttle cable bracket
Fuel
In Tank Walbro 255
Inline Bosch 044
Inline filter w/ -6 push lock lines
PTE 1000cc injectors
AEM rail
Aeromotive regulator w/ gauge
Turbo setup (all built on the car)
Precision .63 a/r 6262 SP w/ ceramic coated turbine housing
GO-AUTOWORKS Topmount combo w/ modular 2 piece downpipe
Tial MVR wastegate
Mac boost solenoid
GO-AUTOWORKS GTC dual backdoor FMIC w/ 600hp Garrett core
3” coldside w/ Tial Q blow off valve
Transmission
B16 transmission (vin matched to the car)
Liberty 5th gear lockout
Solid diff
Drive Shaft shop 2.9 axles
Speedfactory D2B kit
Innovative Solid Billet mounts/anodized black
Competition clutch D2B flywheel
Competition Clutch Twin Disk clutch
Wheels
V2 Competition 13x8 front and 15x3 rear w/ 24.5 slicks/skinnies
Pics:
And the tow rig:
Big thanks to Greg @ Go-Autoworks and my friends that have helped me along the way.
www.go-autoworks.com
VIS Carbon trunk
VIS Carbon lip
New OE front bumper
Interior:
REAL CTR Carpet
No A/C or Heat
AEM A/F gauge
Digital voltmeter
Digital water temp
Apexi boost gauge
Mechanical Oil Psi
No Radio
Suspension
Blox Drag coilovers
EX front LCAs
ARP wheel studs
OE Honda pads
Motor:
D16A6 block
Darton Sleeved
75.5mm 9:1 pistons
Scat rods
ARP headstuds
D16Z6 head
Ported and polished
Crower retainers
Supertech valves
AEM Cam gear
Fuel
In Tank Walbro 255
Inline Bosch 044
AEM rail
Tial MVR wastegate
Mac boost solenoid
Transmission
Solid diff
Wheels
Pics:
And the tow rig:
I do, what exactly are you wanting to see pics of?
Thanks guys.
SpeedFactory, best d2b kit on the market!
Posts like this always make me wonder if people actually read what I posted. Check out the link in the first post, it'll tell you all about the build. The car was purchased as a shell by Go-Autoworks and they already had the motor from Greg's EF hatch, they worked with SpeedFactory for a d2b option for the car.
Thanks man!
Yeah, the dash was dyed black with SEM Landau Black interior dye. Great **** and the interior looks like it came that way from the factory. The door panels were done in black tweed. Every plastic piece on the interior is dyed black.
Thanks guys.
You could if you'd read the thread man.
I'll get some posted, but the speedfactory kit does not use an adapter plate.
Best time on the car at 11 psi was a 12.5. Haven't made a pass yet at 28psi.
Thanks guys.
You're right, what a piece of ****, this car is a complete waste.
Thanks guys.
Haha, thanks man. I got a good deal on it and the suspension and wheels were already done to the truck. My friend was the previous owner, I've been enjoying it.
Thanks guys.
