Parting GSR Block Oil Water Pump, Cooler, Stiffeners, etc.
I have some parts off a couple GSR blocks for anyone piecing one together. First up is a clean Oil Pump, Water Pump, Oil Cooler, and Tranny - Block Stiffeners. PM me if youre looking for something else, I probably have it. (no Crank and Oil Pan). The more you buy, I can knock off a few bucks.
Oil Pump - OBD2 - $65 or OBD1 - $35
Water Pump - $40
Oil Cooler - SOLD
Stiffeners - $25
Thermo Housing - $25
Alternator Mounts - $20
Driverside Motor Mount - $35
Driverside Torque Mount - $35
Crank Pulley - $30
Crank Pulley Gear - $25
Breather Canister - $15
Manifold Brace with Water Pipe - $15
Oil Pressure Sensor - $15
Pistons - Very clean - $12 each or With Carbon buildup - $5 each
Rods - $10 each
Oil Squirters - $5 each
Water Pump - $40
Oil Cooler - SOLD
Stiffeners - $25
Crank Pulley - $30
Rods - $10 each
how much would you do for the oil and water pump? might also be interested in the Stiffeners, already got the oil cooler or else i would get it lol
Is it weird that both gsr engines i had didnt comes with a oil cooler? I spun a bearing so I parted out the block and didnt find one.. Might need it if you still got it
