D15b vtec won't start
Old Dec 16, 2012 | 06:48 PM
Tad's Avatar
Tad
Default D15b vtec won't start
ok so I've had a lot of probes lately.
Right now it just won't turn over.
Cranks for days but nothing.
Recently tried to set the ignition timing, and now it won't start...
Recet ecu, fuses ok.. Idk...
Also I have a vtec 21 code
Just replaced a bad tps
And failed smog... Too lean.
Any ideas???
Old Dec 16, 2012 | 08:07 PM
go-part's Avatar
Default Re: D15b vtec wint start
Check your ecu harness, you may have some bad wires in it. Also check the negative battery cable, make sure it is clean and secured properly.
Old Dec 17, 2012 | 05:58 PM
Tad's Avatar
Tad
any other advice?
i can't find anythign wrong with the cables
Old Dec 17, 2012 | 07:35 PM
Former User's Avatar
Check whether the plugs have bright white spark, the fuel pump primes, and the fuel injectors spray fuel.
Old Dec 30, 2012 | 03:04 AM
Tad's Avatar
Tad
Default Re: D15b vtec won't start
got it,
it was the dizzy.
i think the coil...
TORTUGA
19
Aug 28, 2013 03:08 PM
Phantastic
May 28, 2010 03:15 PM
97_delsol_Vtec
May 4, 2007 04:28 PM
HamiltonRex
Nov 28, 2005 09:53 PM
johnjohn410
Dec 17, 2002 10:21 PM
