OEM GSR B-Series Parts *Paypal Verified
'98 B20B4 Bare Block with main caps/ oil pan/ Mint b20 crankshaft/ type R oil pump/ B20 water pump all in great condition *SOLD
B20 Crankshaft perfect condition *SOLD
OEM TYpe R OEM HONDA oilpump 12k miles $50 SHIPPED
Type R Lower timing cover OBD2. Fits GSR's and B16's with TYpe R oilpumps. $50 with bolts *SOLD
B18B 98 Head Great condition Complete with intakemanifold and sensors $125+shipping.
15" Konig Heliums w/ 80% Hankook tires. **SOLD
92-93 GSR OBD1 P61 ECU (VTEC PULLS HARD) $120SHIPPED
Oem Gsr b18c1 crank pulley w/ hardware small chip on the powersteering belt area(works fine)Sold
B series Alternator OBD1 or OBD2 like new $40shipped
B series Starter like new $43shipped
94-95 OBD1 GSR/B16 LOWER Timing Cover $23shipped
Resistor boxes $23 Shipped
OEM Mounts GSR Driver side $25shipped
OEM Tranny Mount $24shipped
GSR Throttle Cable $23shipped
GSR IACV SOLD
OEM map sensor $15shipped
TPS Sensor $15 Shipped
Lower Power steering bracket 94-01 Integra Stamped P54 w/ bolts $30shipped
94-01 integra Rear T bracket SOLD
B Series Pro-lite flywheel 12lbs *SOLD
All stock mounts , torque mounts, a/c bracket $24Shipped EACH.
GSR halfshaft $40 shipped
Civic radiator single core $40shipped
GSR powersteering pump $40shipped
GSR aftermarket plug wires (blue) $20shipped
GSR A/C Bracket p72 w/ pulley and bolts SOLD
B series alternator Brackets w/ bolts $25shipped
Factory B series radiator hoses low mileage $offer
Low mileage OEM HONDA LS/B16/GSR Timing Belts $20shipped
OEM SET of FLYWHEEL BOLTS $15shipped
OEM SET of Clutch Bolts $12shipped
OEM SET of Headbolts GSR/Type R $20shipped
OEM SET of LS Headbolts $20Shipped
Complete OIL pressure gauge kit new $25shipped
Earls fitted -4an steel braided line LIKE NEW 4ft $25shipped
Paypal: PaintRestore84@hotmail.com
Please add 3% to Total.
I will combine shipping and give better deals for multiple purchases.
I ship items through USPS Priority mail
Pm me if you have any questions or need any pictures. Thanks.
GSR IACV SOLD
"15" Konig Heliums w/ 80% Hankook tires. $500 SHIPPED"
_What tire brand and model?
_BTW, I think your tires (or at least the driver side rear is mounted backward).
Trans mount is 94-01 integra. Not cracked. Rubber is good. 94-97 is what I have
Yes is hydro trans mount all parts are from 94+ integra
I thought you the front tranny bracket thats for the rear. And I thought the fitting for line to connect to the pump were different between obd1 n 2
