2000 accord v6 EGR port cleaning
Old Dec 15, 2012 | 08:23 AM
F16pilotjd's Avatar
Default 2000 accord v6 EGR port cleaning
Have 2000 accord with 175k. Shop changed EGR valve twice and engine light comes on following 10 miles of driving. Heard so tech bulletin 99-085 to clean the EGR ports. Any tips on removing the intake manifold and cleaning ports? Any other routine maintenance I should perform while intake is off?
Old Dec 15, 2012 | 10:35 AM
jdowen2's Avatar
Default Re: 2000 accord v6 EGR port cleaning
FAQ: http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
Old Dec 17, 2012 | 05:33 PM
F16pilotjd's Avatar
Thanks. This should help.
Old Dec 18, 2012 | 09:20 AM
F16pilotjd's Avatar
While I have the intake manifold off do you recommend any routine service? Can I get away with just cleaning the ports and not installing the $147 plastic tube?
Old Dec 18, 2012 | 01:55 PM
jdowen2's Avatar
Clean throttle body and IAC.
Old Dec 19, 2012 | 02:45 PM
F16pilotjd's Avatar
Jdowen2,
This may seem a little basic, but just spray with carb cleaner? Any seals I need to be concerned with?
I am an old plane mechanic and pilot so this newer tech stuff is a challenge to do correctly for the layman.
Thanks
Old Dec 19, 2012 | 04:01 PM
jdowen2's Avatar
Need gasket for throttle body. Just spray with throttle body cleaner. I think carb cleaner is more corrosive but not sure.
shawnvtecordie
Feb 9, 2018 07:35 AM
WizardOfRoz
May 22, 2015 08:37 AM
sween16
Oct 22, 2012 04:42 PM
jojogalan
Jul 18, 2007 12:30 PM
Din
Nov 16, 2006 09:01 PM
