96 accord pulling to the right badly
My 96 accord has been pulling kinda bad to the right for quite a while, my front tires were worn down on the inside, and to go straight down a flat road I had to turn the steering wheel to an 11 o clock position.
So I went and got new tires and an alignment done, but it still pulls exactly the same as before.
I made sure to check to see if the tire pressure was the same and everything worked out there.
Heres the alignment report. Wondering if the specs looked in order, or should I take it back to the shop and ask them to check it again?
http://img28.imageshack.us/img28/7919/imag0314a.jpg
Any and all help would be greatly appreciated
Hmm, do you have aftermarket suspension or stock? Are your springs worn? ( I had this issue about the tire wear, so I put a coil over kit on the car, fixed issue ) Also, have you curb checked your rims? could they have warped somehow?
Thats all that comes to mind for me.
cleancord96
Mar 27, 2007 08:39 AM
