FS: JRSC LS/B18B/B20 Non Vtec Kit, 420CC Injectors, MVM Stepper, Meth Kit
Old Dec 14, 2012 | 02:00 PM
Spawne32's Avatar
Default FS: JRSC LS/B18B/B20 Non Vtec Kit, 420CC Injectors, MVM Stepper, Meth Kit
I regret having to do this but if you havent read my build thread, the timing belt recently snapped on my car, causing me to strip it down and rethink my strategy after uncovering some disturbing things. I've decided to sell the supercharger kit among other things as I continue to part some of the build out. Some things may not be pictured as parts still are still needed to be removed off the car, but the listings are accurate as they describe the product.
IF YOU HAVE QUESTIONS REGARDING ANYTHING LISTED PLEASE PM ME!
JRSC Kit for LS/B18B/B20 Non Vtec w/ Ported M45 Superchrager (serviced twice and recent) - SOLD
Ive had the JRSC kit for a few years now, and its been on two different motors and is in fantastic condition still to this day as I keep up with the service regularly. It has a upgraded coupler inside the snout, and uses GM supercharger oil. The kit includes all the necessary hardware to run the kit as jackson racing originally intended it be used, this includes the following...
Rise Rate FMU
Pressure Switch and Relay system
Standard Double Alternator Pulley
The manifold has been tapped for dual nozzle methanol injection in the back, and I will include block off plugs for these ports at no extra charge. The intake manifold has been port matched to a Hondata phenolic intake manifold gasket, but works fine with standard intake gaskets as well. The pulley systems are not pictured in the photos but are included with the kit, and the idler pulleys themselves are still in good condition with no bearing noise. Im going to throw in the gates racing alternator belt I was using with the kit, but the supercharger belt will have to be purchased separately in an appropriate size, the original belt part numbers (boxes to be exact) will be included with the kit along with the instructions, no carb OE sticker is provided as it was removed when my engine bay was repainted.
Bosch 420cc Type2 EV1 Injectors (OBD1 Only, no box required) - SOLD
MVM Stepper Pulley for LS/B18/B20 JRSC Kit - SOLD (has some knicks and cuts from installation but is otherwise in perfect condition, you never wind up seeing it cus its tucked under the frame rail.)
AIS Trunk Mount 3 Gallon Methanol Injection System with Devils Own 3 Bar Progressive Controller (Includes 2x 2GPH Nozzles on Dual Nozzle System Connector)- $350.00 + Shipping
Crower 402T Non Vtec B18B/B20 Turbo Cams w/ Supertech Dual Valve Springs and Titanium Retainers - $550 + Shipping
Old Dec 14, 2012 | 09:08 PM
Spawne32's Avatar
Default Re: FS: JRSC LS/B18B/B20 Non Vtec Kit, 420CC Injectors, MVM Stepper, Meth Kit
bump
Old Dec 14, 2012 | 09:17 PM
viperjng's Avatar
Hey,
Am very interested in the same provided it can be made to fit my B16A/B18C5 head. Also do I retain Air-conditioning and power steering or loose them as that's very important to me.
Jignesh
Old Dec 14, 2012 | 09:20 PM
Spawne32's Avatar
I cant answer that question, I dont know if the bolt pattern is the same on the B16A/B18C5 vs the B18B/B20B non vtec cars. However I can tell you that the system has no effect on air conditioning and power steering. I had both on my car the entire time i ran it.
Old Dec 14, 2012 | 09:30 PM
viperjng's Avatar
Hi,
If you can find out from some friends there for me would appreciate it. I do remember seeing a post somewhere that said the bolt patterns were different but could be made to fit by doing some minor mods.
You can take this to PM if you wish.
Jignesh
Old Dec 15, 2012 | 09:29 AM
Spawne32's Avatar
bump
Old Dec 15, 2012 | 12:04 PM
Spawne32's Avatar
bump
Old Dec 16, 2012 | 08:59 AM
Spawne32's Avatar
bump
Old Dec 17, 2012 | 10:06 AM
Spawne32's Avatar
bump
Old Dec 17, 2012 | 01:06 PM
Spawne32's Avatar
stepper pulley sold
Old Dec 18, 2012 | 11:44 AM
Spawne32's Avatar
cams and valvetrain added
Old Dec 18, 2012 | 08:28 PM
Spawne32's Avatar
bump
Old Dec 19, 2012 | 02:28 PM
Spawne32's Avatar
bump
Old Dec 19, 2012 | 03:02 PM
Mr. EG's Avatar
Really nice stuff. GLWS.
Old Dec 20, 2012 | 01:57 PM
Spawne32's Avatar
bump
Old Dec 21, 2012 | 09:27 AM
Spawne32's Avatar
bump
Old Dec 23, 2012 | 08:23 AM
Spawne32's Avatar
bump
Old Dec 23, 2012 | 03:32 PM
itr-mugen's Avatar
Nice kit,,, glws
doubleoughtcrv
May 15, 2016 05:20 AM
Spawne32
Northeast (Sales)
Dec 26, 2012 01:16 AM
Spawne32
Dec 22, 2012 08:17 AM
HCivic45
Mar 22, 2006 06:23 PM
BlackThorN
Apr 27, 2004 02:25 AM
