Clutch pedel won't return/disengage clutch plz help !
Old Dec 14, 2012 | 01:13 PM
B_Swapped93's Avatar
Icon3 Clutch pedel won't return/disengage clutch plz help !
My clutch pedel in my 94 GS-R has been getting stuck more and more often and today it finaly won't return to it's normal postion. it also won't make the clutch dissengauge/engauge had to have the car towed what could the problem be im new to cars !
TIA
Old Dec 14, 2012 | 01:16 PM
vtaker's Avatar
Default Re: Clutch pedel won't return/disengage clutch plz help !
Check the clutch master cylinder.
Old Dec 14, 2012 | 01:20 PM
@vtaker what would i be looking for ? a leak or lose hose sorry im new.
Old Dec 14, 2012 | 01:29 PM
khabbs290's Avatar
The clutch master may be leaking externally , you might see it dripping down the pedal inside the car. Or there could be a seal blown internally. It could also be your slave cylinder. Check all the lines as well, the master is right next to your brake master. Follow the lines down to the slave.
Old Dec 14, 2012 | 01:39 PM
there are several cracks in the line going to the slave thanks for the help guys ! this would explain the stickyness of the pedel getting worse and worse as time went on
Old Dec 14, 2012 | 03:52 PM
khabbs290's Avatar
You should replace them with stainless steel, or coated lines.
Old Dec 14, 2012 | 04:32 PM
IN VTEC's Avatar
I've got one you might make use of. I'm not using it anymore and I haven't been able to sell it so maybe it'll help you out.
http://hondamarketplace.com/showthread.php?t=2775550
JDMfan77
Jul 12, 2010 08:54 PM
hannslebo
Oct 8, 2009 04:44 PM
sohctodohc
Mar 17, 2006 03:36 PM
sohctodohc
Mar 5, 2006 02:10 PM
g00se
Mar 8, 2004 06:11 PM
