95 acura integra SE fuel pump problems?
Old Dec 14, 2012 | 07:41 AM
WePoX's Avatar
Icon2 95 acura integra SE fuel pump problems?
hi all im new to fixing hondas and acuras but its alota fun but i have a cupple of questions about my 95 integra se
the car cranks gets spark but will not start, only way i have goten it to start is to put in car in acc and back off again about 4-6 times then it might start
once i get it started and the car is nice and warm after driving for 15 -20 mins i can turn the car off and on as much as i want until the car cools back down this has only started sense the cold weather has came around. ive bin told its a fuel pump or a relay of some kind i know where the pump is but not the relay nor do i know how to test either one to narrow down my problem on a tight budget and was wondering if im going to be giving up my arm and leg to replace the part/parts
car is 100% factory besides audio system automatic tranz
any input would be greatly appreciated thanks for your time guys
Old Dec 15, 2012 | 03:40 PM
WePoX's Avatar
Yea great thanks for all your advise helped me out so much
Posted from Honda-tech.com App for Android
Old Dec 16, 2012 | 09:26 AM
JuicedUpRice's Avatar
Default Re: 95 acura integra SE fuel pump problems?
You have to take into consideration that we are not all sitting here waiting to answer your questions exactly when you want them.Its just now turning afternoon for me,I just got on here since yesterday..if I was getting paid to do this,that'd be another story..lol..
Onto topic
If you hear your fuel pump primes,your main relay is most likely OK.but if you would like,it is located under driver side dash.its a little black box right under the steering column dash area,it says like "relay assly main'' on it with a big 12v on it.take that out and you can try resoldering the contacts,or replace it if you feel.
Check your fuel pressure and see how it looks.if it is anything lower than 30psi,replace it.having to prime it few time before it starting is a pretty good sign that you have low fuel pressure...
Main relay runs 30-80$
Fuel pump(just the pump)50-120$
Prices are ranged far because it all depends if you get new or used,and because I'm sure prices are different depending on where you live
Old Dec 16, 2012 | 12:13 PM
WePoX's Avatar
Cool thanks man i didn't mean to get all pissy, my wife is just up my *** about this didnt mean to take it out on You guys i know you all do your best thanks again
ssdjoey1904
Aug 6, 2014 04:48 AM
CreateAaron
Jun 23, 2014 08:32 PM
andrewzdaname
Apr 21, 2013 07:38 AM
tempname
Sep 7, 2008 05:46 PM
sacjdmz
Aug 27, 2005 12:58 PM
