Transmission & Drivetrain Gearboxes, Differentials, Clutches
JB Welded bell housing
Old Dec 13, 2012 | 10:21 PM
GoodSkoolRevltn's Avatar
Default JB Welded bell housing
Took my trans out of the car to find this! How does it look? I theorize an axle snapped and broke it. Anyone ever done this and got away with a safely operating trans? The gears shifted like butter. On a side note, how much clutch do I have left on this disc? No scoring or ridiculous heat wear on flywheel or pressure plate, maybe a slight glaze. Any input is appreciated.
Old Dec 14, 2012 | 05:06 AM
B.B.'s Avatar
Default Re: JB Welded bell housing
I would never Jb weld my transmission case for the simple fact that you can find a transmission case for cheap and I would rather fix it the right way. Also I know that I wouldn't have to deal with it again down the road. From the pictures I can tell that you did not clean the surface properly before applying the JB weld so my guess is that it is going to fail. Just my 2 cents.
Old Dec 14, 2012 | 07:39 AM
bgdriver's Avatar
If it wasn't leaking when you were using it, I'd just rock on with my bad self.
Old Dec 14, 2012 | 11:48 AM
parts@synchrotech's Avatar
Looks like someone pryed on the case really hard to get an axle out. Probably cracked the case. I would swap out the case and since you have it out...Now is the time to do it and not when it starts leaking later on down the line. Just my opinion.
Old Dec 14, 2012 | 12:11 PM
Crx_owner_20's Avatar
I can't tell from the pictures how close the clutch is to the rivets. If it's close I'd just replace it since its out. And replace the case as well, never know when the one hard shift will split that case open at the weak point.
Old Dec 14, 2012 | 03:48 PM
and i can use any hydro casing if im not mistaken, correct? this is a ys1 trans. i was just at a pick n pull for a few things n saw a ls motor and trans still hanging out.
Old Dec 16, 2012 | 04:44 AM
Aquafina's Avatar
You need a YS1 case. Shim the mainshaft and the diff.
Old Dec 21, 2012 | 05:22 AM
extralargenog's Avatar
Its dark, but it will work. Ive cracked casings and donme the same for a temp fix. It was fine untill I got off my *** and fixed it.
Old Dec 21, 2012 | 05:56 AM
swing_lo's Avatar
I'd suggest you buy a new case as I'm not a proponent of welding tranny components.
Old Dec 27, 2012 | 10:18 AM
If its not leaking right now and dont need to come apart youre fine dont **** with it
Old Dec 29, 2012 | 03:55 PM
poorsupra's Avatar
on my 87 i had to RE-jb weld my trans after an unknown leak showed its head on the bellhousing near the axle just like that. i couldnt find a tranny for a while, worked just fine. id say run it! and just look for a new case in the mean time.
blazin99si
May 30, 2012 07:53 PM
=ITRpoweredEK9=
10
Feb 4, 2006 02:32 PM
ChuloStyle
13
Feb 2, 2005 02:48 PM
Jedi_Sol
11
Mar 30, 2004 03:54 PM
WhiteDA9
Oct 22, 2002 08:12 PM
