my air vents wont blow air!!! help!!
Blower motor is bad, fuse is blown, relay is bad, there is a connection problem, blower resistor is bad, pick one.
Now, how about we start with MM&Y of car so we know what to look for?
The most common problem when blower does not work, [most cars] is the blower resistor is bad, however in most Honda/Acura the fast speed, [#4] will continue to work.
The first thing I would do is unplug the blower motor and test for power, [ign. switch on], If I had MM&Y I could give you a wire color, either way one of the two leads will be power. once you know that, [and if there is power] plug the blower back in and use a jumper to supply a ground directly to the other lead, [just "back feed" the jumper into the blower plug, then ground the other end to the cars chassis] with ign. on, the blower should work. 94
JDM-EJ1
17
Sep 5, 2019 11:51 PM
BrenaNickels
Aug 24, 2008 06:10 PM
thanks tho
