65mm tb on itr maxbore
Old Dec 13, 2012 | 10:57 AM
kulo's Avatar
Default 65mm tb on itr maxbore
Im gunna get my itr 62mm tb sent to maxbore it to 65mm plate to 70mm taper
is this worth it?
Old Dec 13, 2012 | 02:27 PM
redlinetuning's Avatar
Default Re: 65mm tb on itr maxbore
well, if you've already decided you're going to send it in, then what does it matter what anyone says? What is it worth to you? What are your plans for the rest of the motor?
Old Dec 13, 2012 | 05:45 PM
01-0720's Avatar
unless its a built motor or boost its not worth it, thats to big for a bolt on b18
Old Dec 24, 2012 | 07:15 AM
heel_touge's Avatar
If you plan on cams etc in the future I thing maxbore is a great value.
Old Dec 24, 2012 | 07:37 AM
Dave_B's Avatar
What supporting mods do you have? Larger TB usually assumes higher lift cams as well.
Also, what's the price for the bore? You can pick up a 65mm Edlebrock IM for aroudn $250 and sell your stock one.
Old Dec 26, 2012 | 10:48 PM
FlewByU352's Avatar
I recently put a 70MM throttle body and port matched the intake manifold to it. Whether it's too big or not IDK but it is much better than the stock 62MM. After I did quality bolt ons and such my 62MM would stay in vacuum at WOT, no bueno! Now I'm getting 0.4PSI boost pressure by 2500RPM and it bounces from atmospheric to 0.2PSI through the RPM range. Even untuned I haven't noticed a loss at all in performance. My A/F leaned out more meaning air flow definately improved and I temporarily upped the fuel pressure until I get it to the dyno next week. I think the maxbore is a great setup though, basically retaining everything factory. I did only pay $69 for a brand new 70MM though where as the Maxbore is $99.
itr1244
Jul 9, 2018 06:33 PM
turbodailydan
Nov 15, 2009 12:34 PM
BoostnEK6206
Jun 5, 2009 05:32 PM
gakkuken
Oct 20, 2004 09:18 PM
douglas_be
Dec 18, 2003 11:56 AM
