f20b/h22 vss question
Old Dec 12, 2012 | 04:35 PM
sofa_king_kewl's Avatar
Default f20b/h22 vss question
Hey guys I am new to the forum here. I finished my f20b swap and found that my speedo is now 15% off at all speeds. I used my stock D series vss in the t2t4 trans instead of using the vss that came with the swap. Anyone know if I need to put the original back into the car or should the civic vss work fine and I might have another issue instead? Thanks.
Old Dec 13, 2012 | 03:28 PM
Default Re: f20b/h22 vss question
122 views and no one has done an h or f swap??
Old Dec 13, 2012 | 08:40 PM
TrickshoT_CD5's Avatar
it could have nothing to do with that also.. every speedometer is off from the actual speed ure going.. my accord was 8 mph faster then what i was actually going.. it could be caused by a different wheel size, tire size as well. also suspension has to do with it
EGdope
Jun 23, 2012 04:20 PM
baker1218
May 14, 2011 12:56 PM
4.8t
Sep 3, 2010 03:03 AM
PolarMan90
Aug 11, 2008 03:50 PM
Jonathan_ED3
Apr 28, 2003 01:23 PM
