DTR/SSR Header Wiesco K24 12.5:1 Scat k24 rods Supertech Clevite Will trade for K24a2
I'm trying to see if there is any interest in some internal parts from my K24 build. All parts are brand new, in packaging.
Will trade for:
Tuck Harness
Carbon/Kevlar Clutch
ITB
Waterpump Block off
K24a2
Fastest way to contact me is text 248 229 8933
Wiesco K24 12.5:1 87.5mm Pistons, comes with rings and pins $470 shipped
Scat K24 rods, comes with ARP2000 bolts $340 shipped
Supertech K series Valve Springs, these are springs only $140 shipped
Clevite bearing set rod, main, thrust washer $120 shipped
DTR/SSR 4-2-1 Header, Has a 2.5" to 3" cone to flex pipe welded onto it for safety against cracks. The inside of the cone and flex pipe have been smooth out for no disruption in air flow. Will fit EG/DC with K20 or K24. If you have a EK, this will fit with a K20; for a K24 EK, you will need a EG/DC subframe $850 shipped
Random parts:
Sokie Tech hood dampers for Eg Dc Ek $40 shipped
Carbon Fiber airbag tray for Ek $60 shipped
Ground Control sleeves and springs 2000miles $150 shipped
Uncut RBC $200 shipped
K20a2 throttle body with all sensors $150shipped
K20a2 cams with gears $100 shipped
K20 PRB Water pump 15,000 miles $85 shipped
K series valve cover $80 shipped
Uncut K20z3 engine harness $150 shipped
K20z3 throttle body $100 shipped
Will trade for:
Tuck Harness
ITB
Waterpump Block off
K24a2
Random parts:
opiumdaze
May 19, 2007 09:57 AM
