Front end damage on honda accord 1990
So last night I rear ended somebody and my driver side head light was smashed and the hood has been bent up. Everything is still working fine, but i do have a small coolant leak coming from that side.
Just to give you idea of the damage I will post some pictures, but my overall question is whether or not it is worth the time and money to try and fix this, sell as is or try and sell off its parts.
The area you would be concerned with that kind of hit is the top of the radiator support, and see if the radiator itself is cockeyed.
If the radiator is original the plastic tank probably cracked on the top or became dislodged.
Check online at your local Pick N Pull inventory for 90-93 cars.
Hood ~ $50
Grille ~ $20
Headlight ~ $20
If the radiator is damaged RockAuto has them for ~$60.
Peel the tip of the fender back and you could have your car back into shape for ~$150+beer. It may not be pretty but it would work. With only the hood being the tell tale sign. Might get lucky and find a like color hood in the yard.
These cars are good for a solid 250Kmiles easy.
statultra
27
Sep 27, 2009 05:56 AM
