Do I need longer intake studs?
Old Dec 10, 2012 | 06:47 PM
sleeper_92's Avatar
Default Do I need longer intake studs?
I just ordered a Blox V3 intake for my 97 GSR and a Hondata Thermal intake gasket from jhpusa.com. After I ordered it I noticed that they make Blox makes an extended stud kit for the intake when using a Blox thermal intake gasket. Will I be safe with the OEM studs using the Blox intake manifold with the Hondata thermal intake gasket or should I buy the extended stud kit?
Thanks,
Old Dec 10, 2012 | 07:28 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Do I need longer intake studs?
I dont think so.the thermal gasket is not that thick.
Id look into this kit i really was impressed with it.
http://www.outlawengineering.com/HondaB16AFrame.html
Old Dec 10, 2012 | 08:15 PM
drmix's Avatar
I needed to buy extended studs for my GSR when I upgraded to a Hondata thermal gasket and a Skunk2 intake manifold. There was like 3 or 4 nuts that I couldnt get started when installing. The kit I bought was from Oreillys and worked perfectly and was quite a bit longer than stock. Heres a pic of the packaging
The kit comes with studs and nuts but I just used the studs. The kit was less than $10.
Old Dec 11, 2012 | 06:53 PM
sleeper_92's Avatar
I've been looking for a throttle body spacer as well. I'll have to check them out. thanks.
Old Dec 11, 2012 | 06:59 PM
sleeper_92's Avatar
Thanks man
Old Dec 12, 2012 | 01:26 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its not really a plenium spacer but you can ask for 2 or three t.b stacks and use that as a plenium spacer, one thats included in the kit is not enough. I actually ordered a seperate throtle body plenium spacer from ebay, it took forever to come in but i port matched it with all the other gaskets and it works great with the outlaw engineering kit.
grenthang
26
Dec 2, 2004 07:12 PM
PrecisionH23a
Sep 19, 2004 07:38 PM
B18C2_sedan
15
Mar 7, 2004 11:17 PM
B18C2_sedan
Feb 29, 2004 09:29 PM
douglas_be
Dec 2, 2003 01:04 PM
